Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 9th November 2011, 08:48 PM   #381
Russ White is offline Russ White  United States
Russ White's Avatar
How much output swing do you want?
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 10th November 2011, 07:38 AM   #382
Hattori Hanzo is offline Hattori Hanzo  Switzerland
6Vrms (i.e. four times the original 1.5V) would be great.
Old 28th December 2011, 12:28 PM   #383
Nikon1975 is offline Nikon1975  Austria
Russ,
I followed the following advice you gave me, to match the Legato2 with the F5:
"Replacing R1-4 with 357R (.25 or .5W metal film) and R9-R16(CCS Rs) with 1K(.5W metal film) should yield much better results for you. Everything else can remain unchanged."
At first it sounded horrible. The FFT showed very deep clipping and distortion. I managed to reduce the distortion increasing a bit the positive rail of the legato. I set it at 16.5 V. I cannot go higher, both because my supply does not allow of that, and because I do not want to fry the opamp. The negative bias is around 13 V, and looks like it does not affect the distortion Additionally I had to set the reference voltages not at AVCC/2 (1.74 V) but around 1.45 V. Like this it sounds good, and there is no clipping even at 0db.
I am satisfied with the setting, I'd love to understand the reason behind this.
Thank and Happy Holiday,
Davide
Old 28th December 2011, 12:30 PM   #384
Another question: the burr-brown is a drop in replacement for the national, or I should change something else to experiment ?
D.
Old 28th December 2011, 02:07 PM   #385
Russ White's Avatar
Hi Davide,
Wow its been a while. Those values where meant as starting points.
Ok A couple notes. If it was clipping with 357R at R1-4 and 1K at R9-16 you have two choices. Reduce the negative rail to around 12 volts and leave the positive rail at 15-16V. Or, alternatively increase R9-16 to ~1.5K and use symmetrical rails.
I would also set the input bias voltage to 0V (or close). This gives the top half more headroom.
You could use any one of many dual opamps. Just make sure you are in compliance with the datasheet.
Cheers!
Russ
Audio
Old 28th December 2011, 11:10 PM   #386
Yes, I made few detours.
The FFT brought me to the first option, and I will probably stick with it.
Thanks,
D.
Old 28th December 2011, 11:37 PM   #387
Russ White's Avatar
The key is to give keep the output bias at about 3 + ((V+ - 3) / 2) volts.
This gives the circuit headroom (which you will need since you want a large output swing) so it won't clip. You can simply adjust the negative rail until you reach a happy mid point.
Cheers!
Russ
Audio
Old 6th June 2012, 07:30 PM   #388
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I want to use my Legato 1.0.3 for my SE pcm1704, the standard I/V resistor is 150 ohms so I have to change for pcm1704 100 ohms, ok? if ok also I have to change the bottom resistors R20-R24 but due to the fact that I will use Legato as SE I only use the Hot & Gnd with Cold connected to Gnd I need to know wich resistors have I to change R1 & R3 or R2 & R4 also R20 & R23 or R21 & R24? Someone know if have I to change the 1nF & 15nF caps or how calculate the value neede to filter pcm1704?
Thanks for help
Felipe
Old 7th June 2012, 03:11 PM   #389
For my Legato 3 I got a bunch of ZVP2106A to parallel, have I to parallel the marked in red on the attached pic?
Old 7th June 2012, 07:41 PM   #390
avr300 is offline avr300  Denmark
avr300's Avatar
Why do you want to parallel even more FET's ?
If you insists - yes - those are the puppies.
Legato Tweakers Thread...Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
One for Thorens tweakers Klimon Analogue Source 2 11th October 2008 09:05 PM
Priboi tweakers ? Zen Mod Tubes / Valves 4 14th May 2007 08:22 PM
Legato link dac chip,It reads data? Raj1 Digital Source 7 25th April 2007 11:25 AM
For all T-amp tweakers filholder Class D 13 14th July 2005 08:52 PM
