Legato Tweakers Thread... - Page 31 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 27th January 2011, 09:13 PM   #301
BrianDonegan's Avatar
How's the 2.0 manual coming along?
I just need to build up a presentable Legato-2 (all pretty) and take pics for the manual. I can post without the pics for the time being. Should be up later tonight.
Old 27th January 2011, 09:31 PM   #302
Bassivus's Avatar
Originally Posted by Russ White View Post
Sorry, that is not correct. 200ma is just a good starting point. You have to tune the Placid BP to the load. If your load only draws say 60ma, then 100ma (40ma shunted) would be plenty. But if it draws 200ma you would probably want at least 250ma (50ma shunted).
Could you please recommend Placid BP setting for Legato 1 without buffer?
...is I disappear. There is ONLY the music.
Old 27th January 2011, 09:57 PM   #303
merlin el mago's Avatar
It's necessary to change something to run the Legato +15V -13V, it's also other adjust or upgrade?
Old 28th January 2011, 02:55 PM   #304
Personally, I liked 80mA shunted and +15v, -13.5v...
Old 28th January 2011, 07:35 PM   #305
Bassivus's Avatar
did you actually measured the legato power usage?
Old 28th January 2011, 09:21 PM   #306
yes - ~160mA (X2) but unless there is a problem the exact number is not needed. You can directly measure the shunt current across R1 and R2 on the Placid, and simply adjust it using VR1 and VR2.
Old 31st January 2011, 12:23 PM   #307
A question if I may please. On the main TP site there is a seperate wiring diagram for the dual mono IVY III application. I am currently wiring up a dual mono Legato, but cannot find a specific way of wiring it. As something of a beginer here I do not want to make a mistake when wiring. Do I just use the seperate L & R sections from each legato to the relevant Bal & S/e side, or do I need to run from each as the ivy does?
Any help / information / diagrams here would be much appreciated.
Cheers guys.
Steve.
Old 3rd February 2011, 08:10 AM   #308
I have studied the output wiring diagram for the dual mono IvyIII and applied it to the dual Legato, but have become somewhat stumped on where to put the ground from pin 1 on the xlr from each side.
While the Ivy has a different board layout - I am uncertain as to which ground point to send these to on the Legato. Any ideas guys please?
Old 3rd February 2011, 09:38 AM   #309
NicMac is offline NicMac  Italy
NicMac's Avatar
I have noticed the same difference between the IVYIII and Legato boards i.e. there is no central header at the "output-end" of the Legato board. I guess you can connect to any of the Bal or SE ground points. They are all connected to the same ground plane anyway....
Old 3rd February 2011, 09:51 AM   #310
Nic,
Thanks for the reply. I had sort of assumed that it would be ok to do that, but I am trying to keep ground planes seperate in the final build - so if they are all the same point it *should* work perfectly. At my stage of learning this I just dont like making assumptions that could just as easily be incorrect.
I do wonder why the specified ground plane uses the input headers on the IvyIII diagram as opposed to the ground on the outputs used - hence my confusion.
Thanks again for the reply - it's appreciated.
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
One for Thorens tweakers Klimon Analogue Source 2 11th October 2008 09:05 PM
Priboi tweakers ? Zen Mod Tubes / Valves 4 14th May 2007 08:22 PM
Legato link dac chip,It reads data? Raj1 Digital Source 7 25th April 2007 11:25 AM
For all T-amp tweakers filholder Class D 13 14th July 2005 08:52 PM
Copyright ©1999-2017 diyAudio
