Legato or IVY III outputs for Buffalo II? - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 3rd August 2010, 01:22 AM   #31
BrianDonegan's Avatar
Legato is now available.
Old 3rd August 2010, 02:50 AM   #32
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by barrows View Post
If one were to transformer couple the output of the Legato (balanced to balanced) one could likely omit the output caps, and maybe even the filter circuit caps (considering output transformer bandwidth ~150 kHz), is my thinking correct here?
Looking forward to using the Legato, thanks!
Sure, it should work fine, but I have not tried it. One could also do such a thing balanced to SE.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 3rd August 2010, 02:54 AM   #33
Default Thanks...
Russ (and Brian)
Just put in my order for a Legato and a Placid for it.
Old 3rd August 2010, 04:28 AM   #34
sureshm is offline sureshm  Australia
Russ,
Like barrows, I too am keen on experimenting with the Legato. I know it is still early days, but when you get some time, could you please post details (either in the forum or as a manual) on which components to omit to remove the LPF, buffer, output caps etc..
I have ordered my Legato too
Old 3rd August 2010, 05:30 PM   #35
avr300 is offline avr300  Denmark
avr300's Avatar
What happened to the Legato-Placid bundle ?
Never mind, placed an order as well.
Old 3rd August 2010, 07:26 PM   #36
triode4 is offline triode4  United States
Default Legato Power supply
I placed my order for the Legato. I was under the assumption if I have my placid for the Buff II that it would run both.
Old 3rd August 2010, 07:30 PM   #37
The legato requires a bipolar supply (positive and negative rail voltages), so the regular Placid will not work for it.
Old 3rd August 2010, 07:31 PM   #38
Can I change my order? Or is too late?
Old 3rd August 2010, 07:36 PM   #39
It's not too late
Old 3rd August 2010, 07:42 PM   #40
It appears BP power supply and transformers are out of stock, can you not ship the legato and volumite until you get the other parts in?
Buffalo DAC+IVY+OPUS+Dual PS for sale huskydawg9 Swap Meet 13 6th February 2010 02:33 AM
Buffalo DAC, IVY, LCBPS pdrie Swap Meet 2 24th July 2009 03:44 PM
Twisted Pear Buffalo/IVY/LCBPS/LCDPS Hacker Swap Meet 6 26th February 2009 04:57 PM
FS: TwistedPair Buffalo DAC+IVY+LCBPS VT67 Swap Meet 3 23rd February 2009 10:38 PM
Twisted Pear Buffalo Dac and Ivy modules - built - for sale phrarod Swap Meet 3 17th January 2009 02:25 AM
Copyright 1999-2017 diyAudio
