Legato or IVY III outputs for Buffalo II? - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 29th June 2010, 01:21 PM   #21
Russ White's Avatar
Send a message via Yahoo to Russ White
One other note, even if you don 't use the optional class A buffer the output impedance at the balanced outputs is pretty low. Something like 150 Ohms. Many people will elect to go this route to drive power amplifiers as even a 10K load would work just fine, in fact the only effect of the load would be to very slightly attenuate the signal and of course change the corner of the high pass.
Less pulp more juice Twisted Pear Audio.
Old 29th June 2010, 08:56 PM   #22
sureshm is offline sureshm  Australia
Russ, out of curiosity, what do you use for your 'reference' balanced power amp? A Sympatico or some other custom design?
Originally Posted by Russ White View Post
with the DAC directly coupled to a balanced power amp with about 20db gain
Old 30th June 2010, 03:21 AM   #23
glt is offline glt  United States
Originally Posted by nacder View Post
Hi Russ,
I wonder if the Legato concept can be extended to build a power amp. Though we have the chipamp based Sympatico, a well-designed discrete amp will likely have much better performance and this offering would sound very very tempting.
That would be nice. Even with 20 watts it can drive many full range, high efficiency speakers.
www.hifiduino.wordpress.com
Old 30th June 2010, 03:24 AM   #24
Russ White's Avatar
Yes it absolutely could be scaled up. I am not sure what sort of THD I could achieve, but it is in the realm of possibility. I may try it.
Old 27th July 2010, 09:10 PM   #25
Default Legato at twistedpearaudio.com
Russ or Brain,
please check the description of Legato at twistedpearaudio.com.
The text seems to be a copy of IVY.
Cheers
matthias
Old 27th July 2010, 11:01 PM   #26
Hi Russ,
Which SE conversion option would you recommend, the onboard Ballsie or transformers?
How much improvement does the Legato+transformers combination offer over "pure transformers" (directly wired to DAC's outputs)?
Thank you in advance,
Alex
Old 28th July 2010, 10:15 AM   #27
Spev is offline Spev  United Kingdom
Nice to see legato listed on the site! Did I miss a first round of sales, or is it not in stock yet?
Cheers, James
Old 28th July 2010, 03:37 PM   #28
I quite fancy a version with a FET/bipolar CFP - is this part of the kit, or specifiable?
Old 2nd August 2010, 04:36 PM   #29
BrianDonegan's Avatar
Originally Posted by matthiasw View Post
Russ or Brain,
Cheers
matthias
This was a temporary error. I am using the IVY page as a template for the Legato page and was not done editing it.
For those who have ordered an IVY but are thinking they want a Legato instead, I will be adding an option to the Legato page for "Swap my IVY for a Legato". If you select this option, I will ship you a Legato instead of IVY and refund the price difference.
At this point, the only think holding up Legato sales is measuring the total kit weight for automated shipping cost calculations.
I hope to have it all ready to order tonight.
Old 2nd August 2010, 08:36 PM   #30
Default Transformer coupling
If one were to transformer couple the output of the Legato (balanced to balanced) one could likely omit the output caps, and maybe even the filter circuit caps (considering output transformer bandwidth ~150 kHz), is my thinking correct here?
Looking forward to using the Legato, thanks!
Buffalo DAC+IVY+OPUS+Dual PS for sale huskydawg9 Swap Meet 13 6th February 2010 03:33 AM
Buffalo DAC, IVY, LCBPS pdrie Swap Meet 2 24th July 2009 04:44 PM
Twisted Pear Buffalo/IVY/LCBPS/LCDPS Hacker Swap Meet 6 26th February 2009 05:57 PM
FS: TwistedPair Buffalo DAC+IVY+LCBPS VT67 Swap Meet 3 23rd February 2009 11:38 PM
Twisted Pear Buffalo Dac and Ivy modules - built - for sale phrarod Swap Meet 3 17th January 2009 03:25 AM
Copyright 1999-2017 diyAudio
