Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 14th October 2013, 08:31 PM   #481
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
Could you recommend a trafo that does the job (BallSE) for the buffalo dac, but with a maximum cost of 100euro for a pair (stereo)?
I'm that guy who finds ways *not* to do things..
Old 15th October 2013, 03:44 AM   #482
ihear21khz is offline ihear21khz  Malaysia
Seriously, save your money and get a pair of Lundhal 1684. Probably double your budget but these really sound very good. No point wasting money on cheap transformers and then upgrading later.
David
Old 15th October 2013, 09:38 AM   #483
danny_66 is offline danny_66  Belgium
danny_66's Avatar
+1
My vote goes also for the LL1684, it sounds very good.
I have it connected to my es9018 like in this schematic.
Andrea had it compared to other output stages.
My RefSpeaker
Old 15th October 2013, 09:59 AM   #484
Nikitas's Avatar
Thanks guys but it is too expensive for me.
Old 17th October 2013, 03:43 AM   #485
nvduybom is offline nvduybom  Viet Nam
nvduybom's Avatar
Hi Odysseas ,
A member from vnav.vn used jensen JT-11-EMCF for Buffalo III SE, He wrote that he like jensen transformer more than IVY I/V in his system .
Best Regards .
http://www.vnav.vn/forum
Old 17th October 2013, 08:41 AM   #486
Nikitas's Avatar
Hi nvduybom,
I'm expecting delivery today of this little heretical super cheap trafo:
VTX-101-006 - VIGORTRONIX - TRANSFORMER, AUDIO, 1+1:1+1 | Farnell United Kingdom
30 euro for a pair including VAT and shipping. Nice, not?!
I'll try it tonight and report back here
Old 17th October 2013, 03:05 PM   #487
4est is offline 4est  United States
Please bear in mind that the quality of the transformer is a big deal. You may want to look for some old microphone transformers. The 1:10 UTC HA100x(pricey) I am using sound marvelous as compared to the IVY or Legato 3. Wired as per J Rasmussen (thanks for the push btw!) using 2x 5 ohms into my Bent Audio TVC. Plenty of gain with simply superb (low end especially) inner detail while retaining body and dynamics. Note that the lower input impedance will give you a lower freq bass response than spec'd. If it were me, I'd wire yours as 1:4 with 2x 10 ohm. I am curious to hear your results.
Hi nvduybom,
Old 17th October 2013, 03:13 PM   #488
Nikitas's Avatar
Hi 4est,
I'll write my impressions tonight,
What do you mean "wire 1:4"?
Old 17th October 2013, 05:09 PM   #489
1:4 would be the primary in parallel, and the secondary in series for 6db of voltage gain. The dac chip has plenty of power. Adjust the I/V resistors until you have the right amount of gain. Even in this moderate "voltage mode", it is quite nice. The money spent for active circuitry can be put into good transformers. Good old ones appreciate too btw, they are sought for MC phono step up, and can be interchangeable.
Old 17th October 2013, 06:35 PM   #490
Nikitas's Avatar
Thanks!
I don't think I'll try it today, just arrived home from work (it's 20.30 here), way too tired for this....
Buffalo II & transformersHide this!Advertise here!
Buffalo II Russ White Twisted Pear 1912 7th December 2017 03:35 AM
Volumite for Buffalo II? markusA Digital Line Level 15 8th April 2010 02:51 AM
Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II orpheus Digital Source 0 9th February 2010 08:03 PM
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Citation II output transformers dshortt9 Tubes / Valves 10 12th December 2003 03:45 PM
