#391 |
So there is no doubt, I have amended your diagram, so it should look like this:
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#392 |
#393 | |
I have thought about and would explain it this way: Without grounding the mid point, it is for me like a class B amplifier. There is no current, when there is no sound. More loudness means more current, so the dac bounces between more voltage mode (loudness low) and more current mode (loudness high). When grounding the midpoint, we have a class a situation, there is always a current flow. I want to stress again, that the dac in current and hopefully passive mode sounds extremly well and can only be compared to the very best, i.e. Meitner. Best power supply is mandatory, I use LipoFe/NimH cells without any regs. |
#394 | |
If there is always current in primary, can use any transformer without gap ? Untill now, I was using Jensen JT-11-emcf without grounding , with 6 ohms I/V from +- ess9018 output and tube stage 50x gain. Thanks |
#395 |
rolls means current flow that appears on DAC-resister-GND (not on primary)
Right? |
#396 |
#397 |
i also want to thank mr. rasmussen! i listened for some months with a s&b tx103, 1:10, 2x 25R to ground. sounded very nice, but last week i changed to 1:5, 2x 1R to ground followed by a choke loaded 5842(130v, 15ma), choke input psu, superreg and i could not believe it. just fantastic:-))))))
will change the resistors to tx2575, cap to duelund.....nothing will beat this;-) |
#398 | ||
You can do it with 'current' DACs like Burr-Brown 1792,1794,1796 DACs, as these have only a current offset (not a problem to deal with) and no voltage offset (much more tricky) and can be brought straight to Ground anyway. Quote:
Cheers, Joe
#399 | |
Cheers, Joe
#400 | |
so you think it would make sense to use the transformer in 1:20 and just take a wirewrap wire which would give me around 0,25R with a lenght of about 2,5"? at least the transformer was made for voltages like this ![]() cheers,klaus |
| Thread Tools | Search this Thread |
| Buffalo II | Russ White | Twisted Pear | 1821 | 2nd June 2013 07:49 PM |
| Volumite for Buffalo II? | markusA | Digital Line Level | 15 | 8th April 2010 02:51 AM |
| Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II | orpheus | Digital Source | 0 | 9th February 2010 08:03 PM |
| FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
| Citation II output transformers | dshortt9 | Tubes / Valves | 10 | 12th December 2003 03:45 PM |
