#361 | |
Cheers, Joe
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" Last edited by Joe Rasmussen; 2nd July 2012 at 01:31 PM. |
#362 | |
Any comments on the benefits of the SLCF compared to the simple cascoded source follower circuit that I use? This is the 2nd transformer output Buffalo DAC that I've built. The first one used 1:1 transformers and a bipolar diamond output buffer. And it was based on the original ES9008 Buffalo kit with simpler power supplies. This new version has better supplies, newer ESS chip, low value resistive loading to ground (thanks Joe), step up transformers, and the FET buffer. It sounds much "fuller" than the first version. Both have great detail but the first one was a bit lacking in body. This version seems to have fixed that and is very enjoyable. ---Gary |
#363 | |
I don't want to draw the wrong conclusion, but if you are using the fet follower with the constant current source and not the bootstrapped device I am showing, then there is quite a difference. Essentially the SLFF (and SLCF) runs in both constant current and constant voltage modes. It is common to see the CCS - but its also important that the actual follower element sees a constant voltage. What in reality is happening is that input (Grid or Gate), the output (Cathode or Source) and static element (Anode or Drain) are all seeing the same AC signal. Normally followers are one hundred feedback devices, you are using a trick to alters that state. This is a quote from another forum: "Good to hear from you John. It is really fun to watch the SLCF in action. If a 10.00 Vrms signal is applied to the grid, there will be a 10.00 Vrms signal coming out of the cathode, and the plate will also be following along with the 10.00 Vrms signal. They all move together as one. There is no gain or loss of signal, from in to out.... Paul Speltz" Cheers, Joe
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#364 |
#365 | ||
I know this is a little off topic, but I thought I should let you know I switched back from transformers and am quite happy. |
#366 | |
Less pulp more juice Twisted Pear Audio. |
#367 | |
"3" will give you the full output of the DAC, assuming transformer is 1:1 ? "2" will give somewhat reduced output, but give a fuller and more pleasing sound. I would ground the resistors, and even experiment with values. Up to you, see what you like best. Cheers, Joe R.
#368 |
hi, i have one question,
I have the buffalo dac 3 and would like to connect it direcly in my preamplifier, My preamplifier is audio tekne push pull circuit with transformer 30k-30k in cd imput. i know that the buffalo dac is 781 ohm I ask you the matching impedence is realizzated ? the dc osfet it can a problem ? thanks for the Help.... |
#369 |
#370 | |
Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" Last edited by Joe Rasmussen; 25th October 2012 at 07:03 AM. |
| Thread Tools | Search this Thread |
| Buffalo II | Russ White | Twisted Pear | 1820 | 7th February 2013 06:48 PM |
| Volumite for Buffalo II? | markusA | Digital Line Level | 15 | 8th April 2010 02:51 AM |
| Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II | orpheus | Digital Source | 0 | 9th February 2010 08:03 PM |
| FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
| Citation II output transformers | dshortt9 | Tubes / Valves | 10 | 12th December 2003 03:45 PM |
