#341 |
I just received my Buffalo 3 DAC from the good guys at TP, and have been pondering what to do about an IV stage - so this thread has been an interesting read., mainly because TX seems like a very simple solution, and secondly, becasesI already use a TX output on my Cirrus Logic DAC (I have a CS4398 DAC eval board, which conveniently has take-off points on the board directly from the DAC output, before it goes to the op-amp output stage). So 2 questions:
1. Will my Lundahl 1527XL be suitable to with the Buffalo? It's 1+1:1+1, primary DC impedance = 54 ohm, freq response with 800 ohm source = 10Hz to 150kHz +/- 0.2dB - yes, 0.2dB! 2. I hate preamps, and tend not to use one - I have a source selector, and my phono stage has variable gain so nothing else required, however I do have a passive preamp for my existing DAC. Buit can i build variable gain into the TX output by using a switched attenuator across the primary of the TX - this should act as a voltage divider with the output impedance of the bufffalo (I'll work out the resistor values later). I would prefer to switch just one resistor between the +ve and -ve terminals, rather than bother with switching 2 resistors with an ground at the mid point, seems reasonable to me and if it works then the passive pre-amp is gone!! Good, I like minamalist solutions, not complex engineering. BTW I should have said - buiold quality of the Buffalo DAC is superb. Thanks to fellows at TP!! I'm looking forward to getting the DAC built up. |
#342 |
is it possible to use Broskie's Unbalancer as tube line stage in your advice as beau2317 does it in this thread Buffalo III DAC Tube Output Stage Zoran |
#343 | |
#344 |
A2: Try the volumite. It doesn't get any more minimalist then that. I use one with the buffalo and transformers and it works fine.
#345 |
sorry repost, i think this is the right place for ideas
hi guys i setup my buffalo to run stereo mode using the Leon's guide. Thanks Leon. i use qls qa 550 as a source for the I2S inputs. when connected to the sabre. the lock LED is on. then i use transformer for the output. i connect the out + and out - to the primary of the 600:600 transformer. then connect the ground to the secondary side of the transformer to have the Single Ended out from the transformer. I does sing nicely. but there is a distorted sound that follow the music. its very obvious when playing vocals and music seems noisy. All the switches are set to OFF. input voltage is 5.25v and using all tridents. any idea is really welcomed and appreciated. regards, erwin |
#346 | |
Try to disconnect the GND-to-Secondary connection.
/S Quote:
#347 |
Hi Staccatiss
I have tried disconnect the ground. Still distort Any other idea? How to try just the buffalo without any analog stage? Can I put capacitor on the out (+) and ground for the output? Does it tell anything? Thanks Erwin |
#348 |
Hello !
Do you connect ESS output to transformer's primary, without any resistor ? What is transformer's DCR value ? R.C. |
#349 |
Hi RC
yes without any resistor. straight from output of BIII to transformer. the dcr of the transformer is around 500R i have few transformers. the other i tried has less than 100ohm regards, erwin |
#350 |
So , I've done the same without any problem :
ESS V2 +- connected directly to Jensen JT11-HFMPC, secondary to RCA out, but no grounding ! Works perfectly ! R.C. |
| Thread Tools | Search this Thread |
| Buffalo II | Russ White | Twisted Pear | 1820 | 7th February 2013 06:48 PM |
| Volumite for Buffalo II? | markusA | Digital Line Level | 15 | 8th April 2010 02:51 AM |
| Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II | orpheus | Digital Source | 0 | 9th February 2010 08:03 PM |
| FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
| Citation II output transformers | dshortt9 | Tubes / Valves | 10 | 12th December 2003 03:45 PM |
