#221 | |
Less pulp more juice Twisted Pear Audio. |
#222 |
Location: Southern Italy - London (UK) - Philadelphia (US)
#223 | |
If you go back through the posts, see the ones that discusses the lighter tonal balance of the Sabre DAC is Voltage mode. If you want to use Voltage, then transformer is the way to go. Many have heard me say that many times over, that with a differential voltage output where any DC offset will not be seen by the Primary of the transformer. But the Sabre DAC is not a conventional Voltage DAC. The Sabre DAC has a much higher output Z than is usual for a Voltage DAC and hence there is reason to point to it as the cause of the light tonal balance when used as such. We need to reduce that Z and also force the DAC into current. So, Voltage mode, use: ![]() The two resistors force the Sabre DAC into 3.14mA current offset while reducing offset voltage from 1.65V to about 1V. The output will be 1.3V RMS. But how could this be applied to using Tubes and Current mode. Pretty much all the post-DAC Tube designs I have seen avoid full-on Current mode. But with the Sabre DAC there is and opportunity if employing above suggestion repeated here: ![]() We can force the Sabre DAC into Current mode by pulling it virtually down to 0V DC and then get an offset current of 8mA. Using the same 1:1 transformer, it now opens up the way to use Current mode with Tubes. So the above example shows how it can be done. The point is that the Sabre DAC has flexibilities in the way that no other DAC has and using it in Plain Vanilla Voltage mode can be avoided as IMO it gives worst performance. Cheers, Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#224 |
Hi Russ
Indeed it will. The maths are simple. With the example shown 30mV RMS and if a full output of 2V is required, then the tube gain needs to be 66 approx. But most of us can get away with less than that. The 3R value can be tweaked too. I am not about to do it myself, at least not for now but might a little further down the road, or likely help a fellow DIY'er to do it, that being more likely. Cheers, Joe R.
#225 |
Hi
I tried the BII with 600:600 transformers, 10k:10k and 150:10k transformers so ranging from current to voltage mode with minimal changes to the output stage (tube): best result so far I had and sticked to is with 10k:10k transformers, it seems the sabre likes this high impedance better. |
#226 | |
Hi Joe
so if I got you right, suppose I'll go for "C", you are saying that with 1.3V RMS I go straight to my tube preamp (?) Best Pierre |
#227 | |
Could you suggest suitable transformer parameters for ES9018 dac in current mode?
If for pristine and pure adoration - it's diyAudio dedication! |
#228 | |
Schematic?
Thanks JD Quote:
#229 | ||
Others may choose to comment on this? Cheers, Joe R.
#230 | |
![]() I would likely use 15R = 1.35V RMS out. Cheers, Joe R.
| Thread Tools | Search this Thread |
| Buffalo II | Russ White | Twisted Pear | 1820 | 7th February 2013 06:48 PM |
| Volumite for Buffalo II? | markusA | Digital Line Level | 15 | 8th April 2010 02:51 AM |
| Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II | orpheus | Digital Source | 0 | 9th February 2010 08:03 PM |
| FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
| Citation II output transformers | dshortt9 | Tubes / Valves | 10 | 12th December 2003 03:45 PM |
