Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 8th November 2011, 02:14 PM   #211
commstech is offline commstech  Singapore
for Option D, i would think that the DCR of the 600:600 is not crucial due to the 3ohm resistors in parallel to it.. but how would a higher DCR eg. 200Ohm affect Option C or even B against the recommended 100ohm DCR ?
Old 13th November 2011, 02:10 PM   #212
staccatiss is offline staccatiss  Germany
I have finally connected the synchronous Buffalo2 to the SDTrans384 running version 17 and 3.11. I am now also using the Feastrex urushi-treated transformers with the Caddock TF020 4k02 Tetrinox resistor, the Reliable Capacitor 10n Teflon and Tin foil capacitor as transformer load, cryod purest solid core copper wire, and solid core cotton insulated silver wire together with Furutech rhodium RCA connectors. The Buffalo2 has no Tridents. SDtrans and Buffalo2 are powered by separate transformers+rectifiers+regulators.
Music has never sounded as good as this before! Most notably, the music swings, that is, the music makes my feet tap automatically, and sounds organic. Stereo depth/front/sideways has increased. And, there is a blackness of the background and in between instruments that is awesome. Sibilants (for ex s-sounds) sound non irritating (when the recording is not too bad). Voices are fantastic. It is easier to hear individual voices in a choir, and the echo of Mark Knopfler´s voice in "Private Investigation" is easier to pick out.
During playback of one of my reference songs, the saxophone sounded as it stood just to the left of me - I almost fell of my chair. Almost scary.
The only weakness I find is that the bass could have a bit more weight but maybe I need to get bigger speakers instead.
Bunpei - thank you very much for bringing me the SDTrans and Feastrex transformers!
/Staccatiss
Old 13th November 2011, 03:57 PM   #213
Some images attached.
/Staccatiss
Old 13th November 2011, 09:01 PM   #214
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Try a pair of resistors, depending on the configuration of the Buffalo and how many DACs are in parallel, 330R (4 Stereo) of 100-180R (8 Mono) from either phase to ground - the tonal balance and weight should improve in any system. It's only a pair of resistors, nothing to loose.
Cheers, Joe R.
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation but as a question." Niels Bohr
Old 14th November 2011, 09:00 AM   #215
Originally Posted by albertob View Post
Hi all
I have ridden a BII with an output stage Legato v3. It sounds fantastic!
I'm thinking add a valve output stage. Something like "Minimax DAC PLUS". I think this dac does change through relays.
Hi Al
Somebody should really try this:
Gain of tube stage of about 50 should give you near 1.5V RMS output.
Cheers, Joe R.
Old 14th November 2011, 10:48 AM   #216
albertob is offline albertob  Spain
Hi JOE,
thanks for your reply, but do not quite understand your graphic.
My question is about the relays in the signal path between the dac and output stage.
Old 14th November 2011, 03:47 PM   #217
Coris is offline Coris  Norway
Coris's Avatar
Buffalo II & transformers
Staccatiss if you will have a quite large capacity on the AVCC pins of the ESS9018, then you will have that bass you want/wish. And even more...
As I understood, you do not use Trident. If you use serial regulators for Buffalo, then you can just proceed with this suggestion.
You can just solder some extra ceramic caps (100µ/6V) over the existing ones on the Buffalo board. Or in the way you can see in my picture of the first post in my thread. You can solder together in a pack few or more such ceramic caps and then attach the packs over the existing caps for AVCC pins. It could be enough with two packs on each side of the chip.
I do not have your audio system configuration, but with mine (quite simple one, and hand made), I can well recognize your described sound (scene). I just wonder how it could sounds your system with the proposed above solution...
Old 21st November 2011, 09:08 PM   #218
AndriyOL is online now AndriyOL  Ukraine
Originally Posted by Joe Rasmussen View Post
Hi Al
Cheers, Joe R.
What is the purpose of the transformer if you have voltage output?
If for pristine and pure adoration - it's diyAudio dedication!
Old 22nd November 2011, 03:07 AM   #219
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
It converts balanced working to single ended.
It acts as an HF filter . . . .
Also some people like the sound of transformers
Old 22nd November 2011, 09:49 AM   #220
WDYSUN is offline WDYSUN  Italy
WDYSUN's Avatar
Location: Southern Italy - London (UK) - Philadelphia (US)
what would happen if you don't have the tube stage in the schema, but ths signal would go with a short wire to a buffered tube preamp with a short wire? Would the trafo output still work ?
Best
Pierre
Buffalo II & transformersHide this!Advertise here!
Buffalo II Russ White Twisted Pear 1912 7th December 2017 03:35 AM
Volumite for Buffalo II? markusA Digital Line Level 15 8th April 2010 02:51 AM
Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II orpheus Digital Source 0 9th February 2010 08:03 PM
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Citation II output transformers dshortt9 Tubes / Valves 10 12th December 2003 03:45 PM
