#161 | |
could you share simplified scheme of point 3 and 4 ? |
#162 |
3. SRPP -> The Valve Wizard- SRPP
4. diff preamp http://rapidshare.com/files/448854915/ls60_balance.pdf ofcourse for you should modify circuit for tube you choose. and one more thing. If you want to connect DAC directly without caps you have to recalculate cathode resistors to compensate DAC DC offset. |
#163 |
I am in the interim tried using a step up with 28dB gain. The primary is 1.5R and secondary is 400R, with good results, appreciate some advise if this is safe for longterm usage?
Do you reckon if any of these could be adapted to work with B-II, which would be ideal? a) 6SN7 SRPP by diyhttp://analogmetric.com/ebay/6SN7%20Preamp%20schematic.JPG b) ebayer raindrop_hui's SRPP tube output module coupling transformer Thank you |
#164 | |
#165 |
Step up trafo you use is ok for long term use.
You should load secondaries with a proper resistance (as low as possible) to allow DAC see low impedance (to put Sabre outputs to work in near current mode). From my experience step up trafo is not the best choice with Sabre32 chip - it is not typical current out DAC and it seems working better in voltage mode with 1:1 trafo (like Jensen JT-11P-1). If you plan to use tube output the best choice is leave trafos and put positive DAC output DIRECTLY to tube grid without any capacitor (you should recalculate cathode resistor to compensate Sabre DC offset) SRPP is good choice but that one form analogmetric is based on 6SN7 tube which has definetely to much gain for voltage mode Sabre and to high output impedance. |
#166 | |
Location: Southern Italy - London (UK) - Philadelphia (US)
What do you mean by "long term use"?
You should load secondaries with a proper resistance (as low as possible) to allow DAC see low impedance (to put Sabre outputs to work in near current mode). Quote:
Best Pietro |
#167 |
Every trafo is safe to use with Sabre DAC, but not every will work as you wish.
If you use 1:1 trafo you do not have to load secondaries with any resistance - just connect it directly to you amp/preamp. |
#168 | |
Pietro |
#170 | |
I use a Lundhal trafo, so I wrote to Per Lundhal with preamp specs and he gave me the right resistor to load the trafo... it works very good, and I don't undesrtand this "long-term use" thing mentioned previously. ciao Pietro |
| Thread Tools | Search this Thread |
| Buffalo II | Russ White | Twisted Pear | 1820 | 7th February 2013 06:48 PM |
| Volumite for Buffalo II? | markusA | Digital Line Level | 15 | 8th April 2010 02:51 AM |
| Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II | orpheus | Digital Source | 0 | 9th February 2010 08:03 PM |
| FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
| Citation II output transformers | dshortt9 | Tubes / Valves | 10 | 12th December 2003 03:45 PM |
