Buffalo II & transformers - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 3rd October 2010, 06:24 PM   #121
Originally Posted by fred_com View Post
Hi guys
Is there any proven circuit for connecting 600:600 transformers (I'm using UTC A-20's) to the Buf II? Just straight from the output to the primaries? And what about the secondaries - RC filter, or just a resistor?
Thanks,
Fedor
Hi Fedor
Just as an experiment I am trying UTC A-20's on the IVY 3 as balanced to SE converters connected to the balanced outputs. I realize this goes against the TP design philosophy but it's just for fun. It works well anyhow apart from a slight buzz. I'm wondering should I connect the balanced output GND to the UTC A-20 GND pin?
Below is the filter setup I am using for secondaries. The primary resistor values can be played around with to suit. The transformers are configured as 1:1 -
Rich
Old 4th October 2010, 11:45 AM   #122
BrianDonegan's Avatar
How so?
Old 5th October 2010, 04:30 PM   #123
Originally Posted by RichLund View Post
Hi Fedor
Hi Rich,
Sorry, I can't answer your question, I don't have an I\V stage, and right now I've just connected +/- terminals of the DAC straight to the transfomer primaries. I'm using the same filter on the secondaries (left from when UTC's were connected to the Gigaworks Dac).
Thanks,
Fedor
Old 5th October 2010, 08:11 PM   #124
Hi Fedor
Sounds like we are beating the same track. I also have the Giga DAC which I used the A-20's on. It made a massive difference to that DAC but only slight difference when used with the Buffalo IVY.
I have been switching between the standard IVY SE outputs and the the transformer outputs and I have to say I quite like the transformers. A warmer, analogue presentation. Slight loss of ultimate clarity maybe but very comfy. I may sell the A-20's and try Jensen JT-11-EMCF or some Onetics. I have also connected the signal GND to the GND tab of the A-20's and it reduced the hum significantly.
Are you using resistors on the primaries when direct to the Buffalo?
Rich
Old 5th October 2010, 11:01 PM   #125
Connecting the signal GND to the chassis fixed the hum for me. Maybe I should try the transformer GND instead, sounds like a better idea.
Old 6th October 2010, 09:56 AM   #126
Hi Rich
Thanks for the tip about connecting A-20's GND to the Buff II output GND - just tried this using a wire, and hum level is indeed reduced a lot.
I'm not using any resistors on the primaries at the moment. Actually, I'm unsure what resistors values to use and how to connect them, if they are needed.
There's one circuit I wanted to try, and maybe will do it later. Other than that, I'm stumped.
<offtopic> BTW, thanks for the idea of VREF mod on Giga DAC - it made a final point in the series of the mods on this great DAC. </offtopic>
Fedor
Old 15th October 2010, 10:56 AM   #127
WDYSUN is offline WDYSUN  Italy
WDYSUN's Avatar
Location: Southern Italy - London (UK) - Philadelphia (US)
Hello Folks!
I used the Lundahl LL1690 with the Gigawork (CS4398 and CS4397 versions) with huge results. In that case I connected the trafo as suggested by Per Lundahl, tha is: dac connected to the trafo with no additional components, a single 7K resistor across pin 9-10, pin 3 grounded... that's it!!!!
Le me ask some questions:
1. If I understood right the Buffalo doesn't need a SPDIF receiver, is that correct?
2. did somebody tried the LL1690 with the Buffalo II?
3. any comparison with the Gigaworks dac?
Best Wishes
Pietro
Old 15th October 2010, 12:41 PM   #128
Hi Pietro
1. Correct you can connect the input straight to the DAC. However I understand that the Wolfson chip on the receiver module considerably reduces jitter so may well sound better. This is something I'm about to try myself.
2. They should work no problem if I got my A-20's to work with it. The Lundahls should sound good.
3. I also have the Giga DAC and as good as it is, it's nowhere in the same league as the Buffalo. The Buffalo really is a superb sounding DAC. If your'e thinking of getting one... do it.
Hope that helps
Rich
Old 15th October 2010, 02:15 PM   #129
WDYSUN's Avatar
Hi Pietro
Hope that helps
is the difference between the two dacs that drammatic? And if yes, what are the relevant parameters based on which you judge the BUffalo to be superior?
Best
Pietro
Old 19th October 2010, 09:29 AM   #130
I've done this, definitely worthwhile if you have a source with significant jitter.
Buffalo II Russ White Twisted Pear 1862 30th October 2016 12:25 AM
Volumite for Buffalo II? markusA Digital Line Level 15 8th April 2010 02:51 AM
Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II orpheus Digital Source 0 9th February 2010 08:03 PM
FS- Twisted Pear Buffalo 32S Board &amp; System New &amp; Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Citation II output transformers dshortt9 Tubes / Valves 10 12th December 2003 03:45 PM
Copyright 1999-2017 diyAudio
