Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 28th June 2010, 11:02 PM   #91
Rosendorfer is offline Rosendorfer  Poland
io
very nice tests...thanks
This shows why trnsformers help to produce "better" bas...
But You wrote " Hand made 1+1:2,2 ratio transformer ..."
Hand made transformer...????
Rosendorfer
Old 29th June 2010, 07:30 AM   #92
Marek is offline Marek  Poland
io, what DCRs and inductances your transformer has?
Did you connect center tap (if you got it) to GND or you leave it unconnected?
Old 29th June 2010, 06:40 PM   #93
io is offline io  Hungary
Primary bifilar 12 ohms dcr serial (2x6ohm) 6Hy 0.32 mm silk insulated
secondary 82 ohms dcr 28Hy 0.21 mm silk insulated.
GND terminals from a secondary RCA outputs
io
Old 30th June 2010, 05:53 AM   #94
io
What about core for Your Hand Made trafos...??
I bet next step will be silver wire.. ....
Anway great idea to have Your own trafo.
Sounds like Lot of Fun.
Tel us bit more about it maybe some photo...??
Rosendorfer
Old 1st July 2010, 12:56 PM   #95
Rosendofer
I stopped development, I expect enpay amorphous core.
The picture shows the last three versions.
io
Old 2nd July 2010, 12:11 AM   #96
io
Respect... amazing job..
You are real TRANSFORMER.man.
All the best...
Rosendorfer
Old 2nd July 2010, 12:14 AM   #97
jrenkin is offline jrenkin  United States
Love the tablecloth...;-)
Old 2nd July 2010, 03:36 PM   #98
jrenkin
Are You thinking of group buy...
As far as I know there is nobody else trying to make his own trafos specially for our "beloved Buffalos".
I hope that with some more efforts io will come out with "Hand Made io-Trafo" for Buffalo …
Sounds interesting ….
Rosendorfer
Old 3rd July 2010, 08:16 AM   #99
Rosendorfer
I'm just experimenting their own entertainment, there are no plans to sell a transformer.
io
Old 5th August 2010, 06:28 AM   #100
manamanam is offline manamanam  Greece
Hello everybody,
Did enybody try output transformers with two buffalo II as dual mono ?
In dual mono mode i see (from the connection diagram with the IVY) that all 4 output signals (OUT_R+, OUT_R-, OUT_L+, OUT_L-) are used per channel, instead of 2 output signals per channel in stereo mode .
What would be the transformer connection diagram then?
Buffalo II & transformersHide this!Advertise here!
Buffalo II Russ White Twisted Pear 1912 7th December 2017 03:35 AM
Volumite for Buffalo II? markusA Digital Line Level 15 8th April 2010 02:51 AM
Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II orpheus Digital Source 0 9th February 2010 08:03 PM
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Citation II output transformers dshortt9 Tubes / Valves 10 12th December 2003 03:45 PM
