Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 18th November 2010, 10:10 PM   #931
Steamerzone is offline Steamerzone  Netherlands
I believe the filter has 512 taps. Damn maybe i should've singed up for that nda.
Two dollar pic controller with serial interface to a pc and connection to the dac...ultimate tweaking machine? Cheaper and more fun than that demo board.
Old 19th November 2010, 10:45 AM   #932
David Garretson is offline David Garretson  United States
Russ, thanks for the link to the traffo thread. For purpose of powering Buffalo DAC, will a Placid reg work on 12.5Vdc battery power?
Old 19th November 2010, 10:48 AM   #933
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo II
Yes, it will work fine.
Old 19th November 2010, 01:14 PM   #934
Ared is offline Ared  Hungary
Is it possible to use a single transformer to power both a palcid and a placid bp? If so what kind of transf is recommended?
Old 19th November 2010, 01:24 PM   #935
Russ White is offline Russ White  United States
Russ White's Avatar
While it is possible it is not advisable.
You can use one trafo that has 3 secondaries (not very common but can be made).
You can you one dual trafo and share the same secondary that is used for V+ on the bipolar supply for the digital supply. Be very careful here, if you use the other secondary you will make smoke.
You will need to make sure your trafo is sized appropriately in either case.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 19th November 2010, 02:29 PM   #936
Russ White's Avatar
Originally Posted by WDYSUN View Post
is that possible to leave the signal "unfiltered"? Any filter will introduce distorsions in time domain
...we don't listen to averages over time, we listen just in time!
Pietro
Yes you can completely disable the filter.
Audio
Old 19th November 2010, 02:33 PM   #937
Russ White's Avatar
Originally Posted by DSP_Geek View Post
I happen to know a tiny bit about filters. What are the constraints (taps, etc)?
Unfortunately I am afraid if I persue this I am going to get into NDA trouble.
The short of it is all the info you need is in the DS.
I have created several filters using Octave. I have been reluctant to promote that feature for DIY until I get permission to discuss that portion of the datasheet.
Cheers!
Russ
Audio
Old 19th November 2010, 02:48 PM   #938
labjr is offline labjr  United States
I wonder why ESS is so secretive with the data sheet?
Old 19th November 2010, 02:51 PM   #939
Russ White's Avatar
I don't know, but its long been a thorn in my side.
Audio
Old 19th November 2010, 03:14 PM   #940
Not like the competition can't get the data sheet. All they got to do is sign a NDA or have someone else do it.
I like how Microsoft manufactures everything in China, then expects the US government to go after the Chinese diplomatically for all the software piracy.
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 10:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 05:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 07:03 PM
