If the AVCC LED is not lighting this leads me to ask:
What is the supply voltage while it is not lit?
5.36V
Ok then it sound like you may have damaged your AVCC module.
Could you sell me a new one?
Russ isn't the AVCC module: I powered the BII with two lifepo batteries of 3.3V & The BII still does glitches/dropouts.
Just a quick follow up to my dropout questions of a few weeks ago. Please recall that I was experiencing dropouts on the order of 1/minute when using the USB receiver/DAC to feed my BII over I2S.
Last weekend I switched over to S/PDIF on the USB receiver and BII and as expected, no dropouts. I have not done enough listening to have an opinion of the SQ difference. Would anyone like to offer their observations wrt the BII and a feed from I2S vs S/PDIF?
- David
- David
If you have an LED not lighting on the AVCC module something is very definitely wrong.
Thanks Russ, how can repair the AVCC module? I think will be better a new one, could you supply me?
PM Brian and see if he has a spare to sell you.
What voltage do you measure at your analog outputs?
hmm, thats not good. That may be why you AVCC module LED is not lighting.
It sounds like the DAC analog section has been damaged.
Either that or your output stage has extreme differential on the inputs.
How can do?
I am not following you.
What are you using as an output stage?
Owen (opc diyaudio user) I/V (A New Take on the Classic Pass Labs D1 with an ESS Dac)
http://www.diyaudio.com/forums/digital-line-level/154866-new-take-classic-pass-labs-d1-ess-dac.html
What are the voltages at the outputs of your AVCC module to GND. Let me guess... .944V right 1.962V left.
- More Vendors...
- Twisted Pear
- Buffalo II
