Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 27th April 2010, 04:13 PM   #531
Naturlyd is offline Naturlyd  Norway
I have searched the forums but could not find an answer to this:
On the IVY, when used with Buf II, should I use the supplied 2.20K resistors for R32-R35?
I am asking because the manual states "n/a" as the value for R32-R35. From that I got the feeling they could/should be ommited. But from the pictures showing the stacking option, one can see the resistors in place.
Looking forward to listen to it. Great fun to assemble for a novice DIYer.
Cheers from Norway
Old 27th April 2010, 06:31 PM   #532
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default SPDIF problem please help
I do it the setup to configure the B II for SPDIF: changed the input selector in the pcb & used GND for ground & SPDIF for signal & the Led to indicate locked don't lit & the B II don't sound, both Leds on the top of B II are lit, until today the unit was going on very well with setup I2S but now I need to change the setup to SPDIF to connect the hiFace M2Tech 24/192, please help?
Old 27th April 2010, 06:34 PM   #533
Cheers from Norway
Mine is both resistors soldereds R32-R35 & is going on perfectly in balanced mode.
Cheers from Spain.
Old 28th April 2010, 04:09 AM   #534
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
Cheers from Norway
No You don't need them unless you are using the IVY III with the Opus or similar voltage output DAC. but they won't cause any harm either.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 28th April 2010, 04:11 AM   #535
Russ White's Avatar
Try another source to be sure that is not the problem.
And please post this sort of thing on the support forum. Not here.
Audio
Old 28th April 2010, 12:16 PM   #536
I have tried other source (dvd instead pc), now sounds cut off & locked Led blinks lit & don't lit.
Old 28th April 2010, 12:19 PM   #537
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Old 28th April 2010, 04:00 PM   #538
Ok posted in the support forum, thanks in advance for quick help.
Old 5th May 2010, 12:24 AM   #539
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
FWIW I did try some low value impedances, (10, 21, 100, 221R). THD was significantly impacted even with 10 ohms.
This is very interesting, but something needs to be clear to me, when you say 10 Ohm, can this be connected straight to ground or to 1.65V? If there is an offset voltage of 1.65V and connect 195R + 10R to 0V (ground potential), then there will be 8mA going through that 10R (and of course 80mV across the 10R), would the DAC work OK under those circuimstances.
I seem to have seen elsewhere on one of the other forums, somebody using a transformer where the primary centre tap is grounded. It did not show the DC resistances of the transformer's two primaries, but I assume not that high. It was said to work. So the DAC works OK with virtually a real short rather than into a virtual earth floating at 1.65V as suggested by ESS using opamps?
My reason from inquiring is that I would use a differential Low Z I/V into a non-opamp diff amp and not having to float I would make a direct-coupled circuit to bring up to 2VRMS and no coupling cap needed to isolate 1.65V - it would add great simplicity using an existing circuit we have developed, very low noise and its gain can be set to 2VRMS. Indeed 1R+1R I/V Z is workable.
Appreciate your comments.
Cheers, Joe
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 5th May 2010, 12:44 AM   #540
Russ White's Avatar
Cheers, Joe
Hi Joe,
It makes little difference the voltage at the end of the impedance.
The problem is not one of offset but of modulation.
I have a discrete output stage (no GFB) I just built and am testing for Bufffalo II.
It is called Legato. It works wonderfully. It is a common base trans impedance amplifier followed by a CCS feed emitter follower as a buffer. Very much like a D1 but with lower noise.
So far it is sounding wonderful. The distortion is quite low. Not quite as low as the IVY-III but, quite low indeed for having no global feedback.
Its DC bias at the virtual ground is adjustable. It is easy to get it right at AVCC/2 which is indeed optimal at least when no feedback is employed.
The input impedance is less < .2R (I am not sure exactly yet could be much lower).
Cheers!
Russ
Audio
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 10:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 05:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 07:03 PM
Copyright ©1999-2017 diyAudio
