#491 | |
It's always something!
Currently listening to F4 or F6/wSS outputs |
#492 |
Thanks!!
And on that note, Buffalo pre-orders open up again this Saturday at 8pm Eastern Time (US). There will be more available every two weeks. |
#493 |
Question on usage... I'm waiting for the pre-order to open and have a question on usage.
I'd like to go for a dual mono setup with only a spdif input and I/V with a Sowter transfomer. No volume control as it will be used in a controll preamp (lo mu tube)and multiple input select before the amplifiers. Wasn't quite sure after reading the pdf users manual... Will I need two complete Buff2's? A block diagram with the different configurations possible would be nice to refer to. Thanks! Jeff Davison |
#494 | ||
As I posted before, the diagram was already corrected by Russ. Quote:
#495 |
#496 | |
I wasn't questioning the correctness. I just don't see a L_In - on the IVY section of the schematic. I see 2 R_IN - pts. Best Bob |
#497 |
Ah yes, that's simply a typo. I will fix that.
#498 |
Ok here is the wiring diagram for dual mono with the typo corrected at the IVY left input.
![]() Thanks for pointing that out so it could be fixed. Asside from the typo, the diagram was otherwise correct. |
#499 | |
Dear Russ:
I think I understand why the ESS9018 wants to "see" zero impedance, but then we also have 0 Vac output voltage, right? How does one then measure THD (-120 dB)? Regards, Quote:
#500 |
THD+N at digital full scale for the ESS9018 is:
-108 dB when in differential voltage mode -120 dB when in differential current mode - indeed mpressive numbers. But has anyone measured THD from the IVY3? Regards, |
Thread | Thread Starter | Forum | Replies | Last Post |
Buffalo Tweaking | jkeny | Digital Line Level | 316 | 10th March 2010 09:14 PM |
Hello from Buffalo NY | chris emo | Introductions | 1 | 13th July 2007 04:24 AM |
Buffalo brains | macmeech | Introductions | 1 | 15th June 2004 06:03 PM |
New To Site? | Need Help? |
