#221 | |
On the Buf32S it ran pretty warm because of the hot opamps adjacent to it.
Less pulp more juice Twisted Pear Audio. |
#222 |
#223 |
It's because it sounds better. The higher swing gives it better DNR.
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 24th March 2010 at 08:17 PM. |
#224 |
Got my Buffalo II board, thanks!
One question, I am planning on using the Lampizator as the output. What should the loading resistor be? On Lampizator's page, he mentions that 39ohm? Is that correct? |
#225 |
#226 |
You would have to ask the lampizator.
#227 | |
I've read that it's best to use the sabre chip as voltage out when pairing with transformers. What kind of specs would this require for the transformer? Higher DCR of the windings or a resistor strapped across the primaries? |
#228 |
I have a pair of these in my stash and was thinking of using them. Would they work?
Sowter Transformer 9762 DAC INTERFACE* FOR AD1865N-J JD |
#229 |
Mine arrive today, thanks, looks excellent and packaging is good!
Bloody OPA1632 appears to be in short demand and my already delayed back order by RS is nowing showing late July for delivery! Hah, serves me right. |
#230 |
Received today mine Buffalo II, IVY III, Placid & Placid Bipolar & Transformer 2 x 115V 30VA, to use it for 230V I have to connect togheter grey & violet so the fase is brown, right?
| Thread Tools | Search this Thread |
| Buffalo Tweaking | jkeny | Digital Line Level | 316 | 10th March 2010 09:14 PM |
| Hello from Buffalo NY | chris emo | Introductions | 1 | 13th July 2007 04:24 AM |
| Buffalo brains | macmeech | Introductions | 1 | 15th June 2004 06:03 PM |
| Page generated in 0.39174 seconds (100.00% PHP - 0% MySQL) with 10 queries |
