Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 7th February 2013, 06:48 PM   #1821
edionysus is offline edionysus  Netherlands
edionysus's Avatar
Thanx Russ.
I already guessed that getting to root cause of this was a bit ambitious
For now I've added 4% more output to the right channel by changing the balance in the Windows volume settings.
Correcting the issue this way doesn't feel quite right (because it's an hardware issue) but it's the easiest way and does the trick.
...I guess this issue gives me a good excuse to go for a BIII
Cheers
Old 2nd June 2013, 07:49 PM   #1822
mimp is offline mimp  United Kingdom
I've had a stereo buffallo ii / ivy iii / placid / placid bp setup for a couple of years. Recently it became intermittent (audio either dropping in volume by 6dB or so on both channels or cutting out entirely), and has now stopped outputting audio entirely. I'm not using any external control.
The outputs of both power supplies seem fine (went through the setup procedure again just to check) and the AVCC module seems to have the correct output voltage. (~3.6V)
The lock LED comes on when a valid SPDIF signal is present and goes off again when it isn't. The IVY seems ok (connecting its outputs to an input on my sound card and tapping the IVY's inputs with a multimeter probe sees some audio pops coming through on whichever channel I tap)
I've tried a different SPDIF source and cable just in case it was that, but no joy (also tested the source on the input of my sound card, it comes through fine)
Other symptoms:
The MUTE LED never lights. It does seem to switch but only ever gets 0.7V across it so doesn't actually come on. I took it out and the LED is still fine. I've a feeling it hasn't been coming on for a while, so possibly not relevant (it's hidden away in a rack so i'm not 100% sure. It definitely wasn't functioning when the unit was still working but intermittent.)
When I turn the unit off there's a sort of squeak on the left output, like a quickly rising sine tone. Its not particularly loud but clearly audible. I'd also heard this before things went awry.
Any ideas where I should start looking for issues?
Old 23rd October 2013, 12:59 AM   #1823
orpheus is offline orpheus  United States
Default Best place to get 3.3 volts from Buffalo II with Tridents?
I am using the Amanero USB to i2s, and am adding an i2s isolator to the Amanero. The input side of the isolator uses the 3.3 volts from the Amanero, but the output side needs 3.3 volts from somewhere else. Is there a place you would recommend that I tap one of the 3.3 volt supplies on the Buffalo II with Trident 1.1's? Or should I pick up another Trident and power the isolator with it? What would be the best solution?
Thank you for your help.
Aaron.
Old 23rd October 2013, 04:54 PM   #1824
avr300 is offline avr300  Denmark
avr300's Avatar
Between DVCC and GND you have 3.3v
Old 19th January 2014, 11:54 PM   #1825
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Buffalo II
Hi. I finally resumed my Buffalo-II project. I bought the parts years ago. It is running right now but I have a problem that I doesn't seem to be able to solve. My current setup is:
-Buffallo-II with Trident Shunt Regs. The Volumite is on order. The Buffalo is stacked over the MUX. I'm using the I2C interface between both. I'll supply the Volumite directly from the Buffalo.
-LCDPS Supply: One side adjusted to 5.25V (Buffalo-II is using the Trident). I bypass the first R1 CRC resistor to get more current as instructed into the integration guide. Other side adj. to 5.0V, supply the MUX.
-2 Counterpoint ver2 I/V converters. Power supply from one Placid BP (one supply for the two counterpoints. Supply adjusted at +/-15V.
-Ballsie SE converter. This is a custom version made by myself that includes the Legato Ballsie section with buffers (to drive headphones).
The problem I have is a random hiss noise sound, very disturbing with the headphone.
This noise comes and goes. It depends of which parts I touch on the Counterpoint. If I touch some capacitors such as C5 the noise almost disappear. I connected the Buffalo AVCC voltage to the Counterpoint AVCC input.
The noise comes and goes. Very frustrating. Any idea what can be the problem?
Old 20th January 2014, 01:16 AM   #1826
Algar_emi's Avatar
Buffalo II
I think I found the problem. I have just one Placid-BP to supply both Counterpoint and Ballsie Buffer, total supply current +-290ma. I used an external lab power supply to supply both Counterpoint/Ballsie and now the noise is gone, rock solid.
The Placid-BP was designed to supply about 200ma max. I think my Placid was starving on current and couldn't supply all the needed current and/or regulate correctly.
Old 4th February 2014, 08:48 AM   #1827
1543 is offline 1543  Germany
1543's Avatar
Default ferrite beads part#
I would like to uninstall the trident regs on my Buffallo II DAC.
Does anyone know a part# or type of the ferrites beads at L6,L7,L8?
Old 5th February 2014, 02:04 AM   #1828
Russ White is offline Russ White  United States
Russ White's Avatar
Does not actually need to be a ferrite. You can use a simple jumper.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 5th February 2014, 02:45 AM   #1829
Russ White's Avatar
I bet a lot of you might be interested in this:
http://www.diyaudio.com/forums/digit...tter-pear.html
Audio
Old 19th July 2014, 03:13 PM   #1830
Audiohifi is offline Audiohifi  Singapore
Hi Russ White
My present setup is balanced analog output into Broskie Cathode Follower using 6H30Pi
tube. Will Buffalo II see low impedance input? If not, how can I improve the input.
Help appreciated.
Audiohifi
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 09:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 04:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 06:03 PM
