#1781 |
#1782 |
I think it's the combination of nCores with Legato. I know the IVY3 is silent with those.
#1783 | |
I will try headphones connected directly to the Legato to monitor it as well to determine if it might be due to an interaction with the amp. |
#1784 |
Hello - help needed please
A friend of mine put together a Buffalo II with SPDIF connection to my SB Touch. Its been working perfectly for months till yesterday. Both channels stutter or lose volume sometimes, but then resumes normal volume. I noticed that a "power off and on" and everything was fine. I lifted the lid off the case and saw that the D1 LED is not constantly bright - it fluctuates in intensity, almost going out. A power off and a power on, and it burns brightly again. D2 burns fine, and the lock LED is lit, but not the mute. Both Placids are illuminated. Can someone advise the likely cause, remedy. Cheers |
#1785 |
Heat issue ?
#1786 |
No I don't think heats an issue.
The sound stuttered at the very beginning of a listening session, so the DAC was cold. However, it did lose sound almost completely after a couple of hours, but the power off and on meant it was fine again. Thanks |
#1787 |
(carefully) measure the 2 outputs of the AVCC module (both sides).
#1788 |
Dry solder joint(s)?
#1789 |
Thanks for the suggestions.
It might a few days till I can get it checked. If anybody thinks of anything else please sing out. Cheers |
#1790 |
Well the votages were all over the place. So a check of one of the connector blocks to the Placid revealed it was loose. It looks good now, so will run for awhile.
Thanks everyone |
| Thread Tools | Search this Thread |
| Buffalo Tweaking | jkeny | Digital Line Level | 316 | 10th March 2010 09:14 PM |
| Hello from Buffalo NY | chris emo | Introductions | 1 | 13th July 2007 04:24 AM |
| Buffalo brains | macmeech | Introductions | 1 | 15th June 2004 06:03 PM |
