Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 26th May 2012, 09:37 PM   #1771
Russ White's Avatar
Send a message via Yahoo to Russ White
Very likely your DAC was simply running out of current at the higher sample rates. You need to remeber that the DAC consumes more current the higher the sample rate goes.
Less pulp more juice Twisted Pear Audio.
Old 26th May 2012, 09:40 PM   #1772
Can you say Audio?
Thanks for chiming in Russ. Brian suggested as much in an email. I'm using an LCDPS to power the DAC. How would you suggest I check, or increase the current?
Old 26th May 2012, 10:00 PM   #1773
Russ White's Avatar
Lower the resistor value at the CRC
Old 7th July 2012, 04:14 PM   #1774
Russ White's Avatar
I would like some feedback from some of you folks here:
My thoughts on miniature coaxial RF connectors
Cheers!
Russ
Old 26th July 2012, 01:54 AM   #1775
Russ White's Avatar
Quad 2:1 BUS MUX/DEMUX...
Check it out
http://www.diyaudio.com/forums/twist...tter-name.html
Old 26th July 2012, 06:20 AM   #1776
Great!
What is the status for the XMOS USB-interface?
"People can't do what they should: room acoustics and speaker design - so they do what they can: new amps, cables etc." (Lidia)
Old 26th July 2012, 01:18 PM   #1777
Originally Posted by Nelson Bass View Post
Great!
Also - AC2?
Old 26th July 2012, 01:22 PM   #1778
Ared is offline Ared  Hungary
Hey Guys! I don't have plans to upgrade my B2 with tridents at this time, but I'm wondering if in like 2 years I change my mind, what are the chances of them being still available?
Old 28th July 2012, 02:18 PM   #1779
Default tech ?
Recently, I am trying a nCore class D amp with my B-II/Legato (direct connection, balanced). For the first time, the noise floor of the amp is below that of the DAC.
Now I find that there is a clakkity/clak sounding floor of my DAC (sounds kind of like a train track sound). Admittedly, this is way down in level, but I think the floor should be smoother than this?
I put the B-II board in mute, and the sound goes away to reveal a smooth, and very low, noise floor of the Legato (nice Russ).
Before I go on, perhaps chasing wild geese, is a spiky noise floor normal for the B-II, or should I continue to investigate further to try and eliminate it?
Thanks for any insight.
Old 28th July 2012, 03:03 PM   #1780
Russ White's Avatar
A sound like that sounds like it could EMI or some form of HF oscilation (after the IV). That certainly should not actually be coming from the DAC unless for some reason it is enbedded in the digital signal itself, which is possible. It also could be that your amp is very sensitive to HF, and you may need more aggressive low pass filtering. Some class D amps are very prone to this.
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 09:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 04:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 06:03 PM
Copyright ©1999-2013 diyAudio
