Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 5th January 2012, 12:56 PM   #1701
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Joshua_G View Post
What's Sidecar?
It's a BIII accessory:
Sidecar, which is used for switching between S/PDIF inputs and PCM(I2S) or DSD inputs. The module is daisy chained between the S/PDIF receiver (above) and the Buffalo-III. By applying 5VDC to the Trigger header, the relays switch between the S/PDIF inputs and the inputs on the PCM/DSD header, and then to the Buffalo-III. Please note that this module supports only stereo PCM and DSD signals.
Old 5th January 2012, 01:07 PM   #1702
albertob is offline albertob  Spain
Originally Posted by merlin el mago View Post
You can't use Sidecar with BII, that's the reason I bought the BIII
then, that I have to use for Bii?.
If the sidecar is what I need, I can manually apply 5v with a switch. Is that it?
SF Cremona clone DIY speakers
Old 5th January 2012, 06:04 PM   #1703
LeonvB is offline LeonvB  Netherlands
Is there any real benefit of BIIIs in dual mono vs BIIs?
It depends. The added cost of the BIII (and the benefit) lies most of all in the Trident regulators.
If you don't have those on the BII, I'd add them. IMO it's a more efficient way of spending money than blindly adding a second DAC.
If you already have the Tridents, it becomes another question. You could strip the Tridents off the BII, and use them on the BIII. This lowers your cost of upgrading. Reinsert the beads and you have a functioning BII you can sell, plus a set of Tridents to use for a single BIII.
Old 6th January 2012, 02:29 PM   #1704
wktk_smile is offline wktk_smile  Japan
wktk_smile's Avatar
Default Question
Is there simple way to divide 1.2v VDD into digital and analogue ones, except
lifting DAC IC's pin or cutting pattern?
Old 6th January 2012, 03:09 PM   #1705
Russ White is offline Russ White  United States
Russ White's Avatar
No, and there would be no good reason to do so anyway. All the analog 1.2V supply does is drive the gates of the level shifters.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 6th January 2012, 03:27 PM   #1706
wktk_smile's Avatar
I understand.
Just I was thinking about separating PSU for ES9018's digital and analogue sections like VCCs.
thanks!
Old 7th January 2012, 09:04 AM   #1707
Default BII tube/legato v3
Happy New Year!
I have my project almost over. I have a prototipo mounted in a wooden box. It's a buffalo II DAC with selectable output stage between tube and legato v.3. This change is with a switch. I have used panasonic tq2 relays to make the change.
The relays off (no power) give way to LEGATO. The signal path between dac and legato is 4cm.
The relays on (with power) give way to tube-i-Zator. The signal path is 8-10 cm.
At the moment I have a little more length in the cables and they are somewhat messy, until the final place in the box. All signal cables are silver.
I have used shunt regulators for all power supplies. 2X tridents and a shunt regulator for the clock. Some Russian PIO capacitors and bypass ft3. When placed in the final box I put Mundorf silver in oil in output valves and some resistance Texas Instruments.
The DAC is controlled by arduino. I'm yet to put a usb-i2s interfece. Russ / Brian for when we have the usb-i2s xmos?. At the moment it is connected by toslink. My source is a MacMini.
The sound is fantastic. At the moment I do not find differences with the version without relays
The pictures are made with a mobile phone.
Sorry for my bad English.
A design image for the box and the front. It will be a chassis with 10mm front modu.it
Al
Old 9th January 2012, 08:18 AM   #1708
Aleksi M is offline Aleksi M  Finland
Here is my finished build. No arduino. Atmega16 based controller and the board is my own design. Remote control, Em14 encoder for volume/balance and PWM supplying the LCD backlight for brightness adjustment.
Inside pics can be found from the link. Volume control is not yet implemented in the inside pics as they are so old. Volume knob is attached to the encoder with a 7mm bar going through two ball bearings to get that "high-end feel". Also the encoder was not enough to support the weight of the knob by itself.
http://amattsso.1g.fi/kuvat/Audio/DSC_8643_.jpg/
Old 9th January 2012, 12:16 PM   #1709
Russ White's Avatar
Originally Posted by albertob View Post
Happy New Year!
Al
Interesting! Nice build!
Cheers!
Russ
Audio
Old 9th January 2012, 12:16 PM   #1710
Russ White's Avatar
Nice build! Very DIY - very cool! I really like the panel.
Audio
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 09:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 04:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 06:03 PM
