Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 26th August 2011, 06:33 AM   #1561
glt is offline glt  United States
Not quite. They define the absolute phase if used in their default value. But changing some of the dacs will result in undocumented behavior.
(edit) I read your description again. I think it sounds right.
www.hifiduino.wordpress.com
Old 26th August 2011, 07:01 AM   #1562
Nikon1975 is offline Nikon1975  Austria
Glt,
I saw the last version of your code. I made the modifications to use it in dual mono, added the fumction to use selectmode with the remote and the master trim.
Question: what is the story about the de-emphasis? I don't remember TP, but it looks like you disable that. I don't knowuch on the matter, but from what I read on internet, shouln't it be emabled? It appears in two different register values.
Thanks,
Davide
Old 26th August 2011, 12:05 PM   #1563
Russ White is offline Russ White  United States
Russ White's Avatar
The DACB phase registers are relative to the DAC phase of each DAC. They are not absolute.
De-emphasis on the ES9018 is handled automatically if the SPDIF decoder detects that the signal has emphasis. Very few CDs are encoded this way. We just leave this as default since it is only turned on by the DAC when it is needed. Which is truly rare.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 26th August 2011, 03:08 PM   #1564
Thanks Russ and Davide for sharing the info.
I don't think I would have figured it out through experimentation in a million years.
I might add that the remapping behavior also happens when you reduce the number of (digital parts) dacs due to increasing the quantizer bit size.
Experiment: Consider the even dacs. Use 8-bit quantizer (this turns off 2 or the 4 even dacs). If you flip the phase on all the even dacs, you get silence.
This may be a detail for BIII users in dual mono: Use 6-bit or 7-bit and no source remap (and all 4 dacs have the phase flipped) Switch to 8-bit or 9-bit and then you get silence...
Another observation: if DACXB is in relation to DACX, in what situation would you use DACXB in-phase with DACX?
Old 26th August 2011, 05:26 PM   #1565
Russ White's Avatar
glt some of what you are seeing is because of the physical connections as much as the internal remapping.
You should get a B3 so you can play around in earnest.
Audio
Old 26th August 2011, 08:41 PM   #1566
In due time, in due time
Right now is more fun dealing with the limitations of BII
Old 26th August 2011, 11:28 PM   #1567
Guess if you want to turn the chip on a SE output.
D.
Old 30th August 2011, 02:22 PM   #1568
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I want to change my BII 80MHz clock for the new 100MHz clok to avoid drop-outs, it's easy to change? wich 100MHz clock will be plug & play, another Crystek? TP sells separately only the new clock for BII users?
Old 30th August 2011, 02:40 PM   #1569
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo II
You want the Crystek CCHD950-25-100, available from Mouser.
CCHD-950-25-100.000 Crystek Corporation Standard Clock Oscillators
We have them build by Crystek in batches but the quantities are aligned with the DACs we need to build, so we don't have extras floating around. When I prototype, I buy a few from Mouser.
As for ease of replacement, that really depends on the tools and skills available to you. I would typically use a hot-air rework station. Since it doesn't have pins, it's almost impossible to remove with an iron, unless you want to dissect the XO and systematically cut it up (destroy it).
Old 30th August 2011, 03:03 PM   #1570
D.
You are right. Datasheet says that feature is to allow all the DACs to be summed, for example to drive (directly in voltage mode) an amplifier...
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 09:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 04:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 06:03 PM
