Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 17th August 2011, 05:24 PM   #1511
barrows is offline barrows
Default ASRC...
GLT: there are those who feel an ASRC sounds unnatural. Wavelength Audio uses the ESS chip in synchronous clocking mode for this reason. I have not listened to a synchronously clocked B-II or B-III yet, but I would like to try it and see...
As far as clocking goes, the CCHD clock is pretty nice...of course if one provides an I2S source with an equally good MC, and short, well implemented clock transmission lines, all should be good.
I would like to see a USB-I2S source with CCHD (or similar spec) clocks, and dedicated shunts for the clocks' supplies...hint, hint...
Old 17th August 2011, 05:35 PM   #1512
glt is offline glt  United States
barrows,
Absolutely agree.
But since my source clock is generated by the FPGA, there is no way I'm trading that with the CCHD clock.
BTW, I am not too fond of winged Buffaloes (hence I am trying hard to stick with the BII) :-)
www.hifiduino.wordpress.com
Old 17th August 2011, 05:37 PM   #1513
Russ White is offline Russ White  United States
Russ White's Avatar
There is no "Synchronous clock mode" really You are either using a synchronous clock or your not. This actually only effects the very first part of the digital input and OSF.
I am not against using a synchronous clock. But I would never buy into the hype that anything else sounds "unnatural". Because I know better.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 17th August 2011, 05:44 PM   #1514
Default Yeah...
Originally Posted by glt View Post
barrows,
Absolutely agree.
If you have a DDS generated clock it is likely best to stick with the onboard CCHD as MC, agreed then. I have also noted that some reputable commercial DAC designers, who previously did not like the sound of hardware based ASRC implementations have actually embraced the ASRC as implemented in the ESS chips: most notably Daniel Weiss. The ESS approach to ASRC does seem to sound better than many others (TI for instance).
I still wonder what the ESS 9018 will sound like synchronously clocked with a ultra low jitter/phase noise I2S MC source... Gotta try at some point.
Old 17th August 2011, 05:48 PM   #1515
Russ White's Avatar
I would say it sounds absolutely awesome. I have tried it. But the clock does need to be very good. Keep in mind. Things are still internally relocked. Just at an exact multiple.
Audio
Old 17th August 2011, 06:03 PM   #1516
What happens to the filters since they are designed to the internal oversampling?
Old 17th August 2011, 06:11 PM   #1517
Russ White's Avatar
They are still oversampling. You don't need to disable OSF.
Audio
Old 17th August 2011, 06:14 PM   #1518
jgazal is offline jgazal  Brazil
Is it possible to run the ES9018 with a 112.896Mhz clock and then an output signal to run the transport with this same clock?
Sorry if this is something stupid to ask...
Old 17th August 2011, 06:16 PM   #1519
Russ White's Avatar
I think (don't have it open at the moment) according to the datasheet that might be just a tad too high. But it might work.
Audio
Old 17th August 2011, 06:32 PM   #1520
I see, in "normal mode". That means the clock must be >192 FS
Suppose the source clock is 192fs. For 352.8KHz material that means 67.733 MHz. That is still below the 80 MHz of the current clock
Suppose the source clock is 256fs. For 352.8KHz material that means 90.316 MHz. That should be high enough to fix the noise problem
However, I seriously doubt my source is generating that frequency for the MCK.
OK, I think I was confusing "synchronous" with OSF bypass (which requires a much lower frequency MCK -only >24fs)
Passing 100Mhz clocks with simple wiring is probably not a diy type of thing :-)
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 09:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 04:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 06:03 PM
