Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 3rd April 2011, 04:07 AM   #1281
rade95 is offline rade95  United States
Default Buffalo II DAC new orders
Hi Russ,
What is the latest on Buffalo II DAC new orders and shipping? I would like to order one module.
/R
Old 3rd April 2011, 06:02 AM   #1282
Duffy Moon is offline Duffy Moon  United Kingdom
Duffy Moon's Avatar
Originally Posted by rade95 View Post
Hi Russ,
/R
Next stampede of pre-orders? - General Questions - Twisted Pear Audio Support
Old 4th April 2011, 03:42 PM   #1283
francolargo is offline francolargo  United States
For insight into speaker design, I'm trying to get a concrete idea of the nature of Tridents' beneficial effects on B2 performance. Any ideas? Has anybody looked at waveforms? I would be really curious to see (or read about) a closeup of the leading corner of a 3kHz to 5kHz square wave looking for any differences with vs. without Tridents. My ears tell me they should be obviously different but who knows, it could just be a perceptual trick. I'd be curious about other frequencies as well. Anybody done anything like that or able to get that info without much trouble? TIA! [...my ferrites are long gone]
Frank
Old 4th April 2011, 04:29 PM   #1284
Nikon1975 is offline Nikon1975  Austria
Is there any added value, beside galvanic isolation, to use a spdif transformer on input ? What does the data-sheet recommend ?
Thanks,
Davide
Old 13th April 2011, 09:50 AM   #1285
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
At the very first page, there is a tube IV stage mentioned. Any idea about the progress on this? Still waiting for the next pre-order
Old 13th April 2011, 05:30 PM   #1286
markusA is offline markusA  Sweden
markusA's Avatar
Speaking of tube stages, is it a viable option to try for current mode or do tubes equate to voltage mode by default seeing as how current mode requires a very low input impedance?
Follow-up question: Is voltage mode actually a bad thing? So what if the THD drops a little?
Do we have any successful BII builds with tube I/V stages?
Old 13th April 2011, 06:22 PM   #1287
Aleksi M is offline Aleksi M  Finland
Is it safe to connect an external controller with 5V logic level to the buffalo i2c interface or is 3.3V preferred?
Old 14th April 2011, 05:56 PM   #1288
LeonvB is offline LeonvB  Netherlands
1) Dustin told me that the interface pins on the ES9008 and ES9018 are 5V tolerant, but I have never tested it.
Buffalo DAC (ESS Sabre 9008)
Old 14th April 2011, 09:12 PM   #1289
thomaspf is offline thomaspf  United States
My Arduino builds are using 5V straights with no voltage converter and it works fine.
Cheers
Thomas
Old 14th April 2011, 10:38 PM   #1290
Cheers
Thomas
Ok. Good to know someone has tried it. Would not want to be the first to try and find out it breaks the chip . The provided supply lines for i2c are 3.3V even though the dac board is fed with 5-5.5V, so I thought the i2c inputs might not handle higher voltage.
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 10:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 05:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 07:03 PM
