#1261 | |
Are you measuring the correct current? - If you are using the Placid for the Buffalo supply, 65mA looks like the shunt current. If you are using the Pladid check that you are measuring the voltage drop across the correct resistor. I have Tridents installed so I can't comment directly on the standard install but 290mA would seem about right given that after adding the Trident shunts the draw is around 500mA. Regards |
#1262 |
The HiFace puts out almost 5V and can be connected to D1 and ground instead of SPdIF and ground. Turn off the SPDIF switch if using this connection.
#1263 |
Anyone know what the output of the EVO is?
#1264 |
If I remember the Evo have 0,5V at output
Happiness is a warm soldering iron
#1265 | |
D. |
#1266 | |
output from Hiface. SPDIF switch is on. When S\PDIF from Hiface is connected to D1 & GND and SPDIF switch is off (or on), there is not sound. I will do more tests. Sorry for wrong information. Angel |
#1267 |
Did you have the AVCC module installed?
Less pulp more juice Twisted Pear Audio. |
#1268 |
I guess I messed up something while measuring. The real reading is 240mA for each Buffalo and 200 mA for the legato with the balliste installed.
Does it make more sense ? D. |
#1269 |
Yep that sounds about right.
#1270 | |
I thought that the current swing of the Buffalo was rather high and might actually have considered the opposite configuration (two Legatos for one Buffalo). Cheers, Nic |
| Thread Tools | Search this Thread |
| Buffalo Tweaking | jkeny | Digital Line Level | 316 | 10th March 2010 09:14 PM |
| Hello from Buffalo NY | chris emo | Introductions | 1 | 13th July 2007 04:24 AM |
| Buffalo brains | macmeech | Introductions | 1 | 15th June 2004 06:03 PM |
