Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 5th March 2011, 03:32 PM   #1201
tmas is offline tmas  United States
Headrott,
I would be very interested in your experience with the tubeizator boards.
Old 5th March 2011, 04:04 PM   #1202
Marek is offline Marek  Poland
Originally Posted by BrianDonegan View Post
So, the loopback measurement was done SE?
Previously presented measurments was done balanced (PP). Whed I disconnect one balaanced output eg OUT- then 3rd harmonic stays and additionally 2nd harmonic shows up
BuffaloII SE (one complementary output) to EMU:
Old 5th March 2011, 04:35 PM   #1203
Russ White is offline Russ White  United States
Russ White's Avatar
You should not be seeing that degree of 3rd harmonic, something is clearly wrong either with the setup or the measurement. It is not easy to obtain good measurements from a PC solution even from the EMU device. The problem is that the ADC itself can introduce some very nasty errors. This will not really be noticed in a loop-back situation. Also simple things like how you run the measurement cable etc can make very large differences.
Since you are using the DAC in an extremely bad setup (voltage out etc) I am not completely surprised. But your measurements are particularly off even compared with what others have posted here and other threads, but most of those people are measuring complete solutions.
We have had the Buf II tested several times with AP. And we easily achieve the results stated in the datasheet with IVY-III. Legato also comes very very close, but it has no global feedback, so THD is very slightly higher.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 5th March 2011, 04:42 PM   #1204
Russ White's Avatar
Here is a recent measurement at 1khz with IVY
Audio
Old 5th March 2011, 05:06 PM   #1205
glt is offline glt  United States
Marek, very nice. Keep them coming....
www.hifiduino.wordpress.com
Old 5th March 2011, 05:09 PM   #1206
If problem is in EMU's ADC is must be visible on loop test (physical cable from EMU DAC to EMU ADC) but it isn't. Both situations are the same, only different DAC
I use gold plated XRL (CANNON) interconects based on top of the line germany professional microphone cable KLOTZ MY206 soldered with tin and silver.
Since you are using the DAC in an extremely bad setup (voltage out etc) I am not completely surprised. But you measurements are particularly off even compared with what others have posted here and other threads, but most of those people are measuring complete solutions.
Sabre32 DAC in voltage mode should have -108dB THD - its enough for me. I use this setup because of testing tube output stage (tube is voltage driven device).Before I do measure performance of tube stage I need to define source (BuffaloII) and meter (EMU ADC) performance. And I did, and my results are that the EMU DAC with OPAMP output stage has better THD performance that alone BufII (I'm suprised).
I know that datasheet THD is true for sure - I try to figure out what is the reson of my bad results.Maybe I made something wrong or my BufII is lightly broken...
I've just made a test using Jensen JT-11P-1 (1:1) as a simple passive output stage which provide galvanic isolation and BW limiting but THD results are the same..
Have you measured BufII in voltage mode (no output stage) with AP? can you post result here?
Old 5th March 2011, 05:12 PM   #1207
Russ White's Avatar
No, I actually have not measured it like that (no output stage) , because I know the results would be far from ideal. Even in voltage mode you would want to do some form of output stage. Direct is never going to be an excellent option.
Audio
Old 5th March 2011, 05:29 PM   #1208
Ok, got it, but what can I do to stay voltage out (for tubes) and heve better performance?
Anyway I'm wondering in what conditions ESS achieved those -108dB..
Old 5th March 2011, 05:39 PM   #1209
Russ White's Avatar
This is what they show on their site.
Audio
Old 5th March 2011, 05:45 PM   #1210
Yeaa..I was there (in OPAMP world) and never come back again...
I definetaly prefer -90dB 3rd harmonic over -120dB from OPAMP output and I think I'm not alone.
Anyway, thanks for you help.
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 10:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 05:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 07:03 PM
Copyright ©1999-2017 diyAudio
