Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 13th February 2011, 10:27 PM   #1121
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo II
Originally Posted by markusA View Post
Pardon a n0ob question...
I have a BII + Placid kit and I'm about to start the build. I'm considering using a 7.5VAC Wall wart. How should I connect the grounds? I assume neither of the two leads from the wall wart are connected to ground?
I'll be using balanced XLR.
Connect the two output leads of the wall wart to the input of the Placid. Done.
Old 13th February 2011, 10:39 PM   #1122
markusA is offline markusA  Sweden
markusA's Avatar
Thanks, and how about the other grounds?
I'll be using transformers on the output...
The placid has one ground at the output, the BII's got some as well?
Should I route everything to a common chassie ground, wire it all in series or what?
Old 13th February 2011, 11:51 PM   #1123
Duffy Moon is offline Duffy Moon  United Kingdom
Duffy Moon's Avatar
Originally Posted by pellesmil View Post
what should i choose as internal wiring from the bnc to the buffalo S/PDIF
I use 0.6mm solid core bell wire. Works great. I use it for all internal wiring apart from mains. Maybe if I got unwanted noise I'd think about shielding, but I've never had a problem.
Old 14th February 2011, 02:07 AM   #1124
Artemkv is offline Artemkv
Guys, if I am getting this right, by ordering only from TPA site - the best results are achieved by putting together Dual Mono DAC + Ivy + (how many bi and single power boards donno..) + (2 transformers), correct?
Old 14th February 2011, 08:19 AM   #1125
Bassivus is offline Bassivus  Serbia
Bassivus's Avatar
Some thoughts about internal cabling both digital (S/PDIF) and analog output from the IVY, i am willing to spend some $ in the quest for the perfectly naturally balanced cable, am now running Silk Mk2 interconnects and Furutech rca and xlr .
I have partly decided to run twisted pair of the Silk mk2 at the output both balanced and se,
as for digital input i have ordered a Belden 1694A bnc/bnc and will modify my cd player into bnc.
The question that remains is:
what should i choose as internal wiring from the bnc to the buffalo S/PDIF input, the distance is max 2 in,
should i go for
-1694a shielded? might add some mecanical stress since the 1694 is quite stiff
-1694a stripped and center lead used both for + and -
-Silk mk2?
-other?
-other candidates as for the analogue cabling?
-Thanx
Just use some 24awg twisted wire pair, e.g. from striped CAT5 utp cable...
Old 14th February 2011, 10:10 AM   #1126
pellesmil is offline pellesmil  Norway
pellesmil's Avatar
for the dig input?
as for digital interconnect what do you prefeer?
Old 14th February 2011, 10:21 AM   #1127
NicMac is offline NicMac  Italy
NicMac's Avatar
Buffalo II
The CAT5 cable works fine also here. I'm interested in you guys opinions on some nice kind of wire-to-board connector as I find the terminal blocks supplied with the kit somewhat "heavy" for these fine digital signals.
Nic
Old 14th February 2011, 05:54 PM   #1128
Alchamist is offline Alchamist
Alchamist's Avatar
I listened Rega dac last week and it impressed me.
Timpani Audio & Video
could anyone compare buffalo ll and rega dac ?
regards
Old 14th February 2011, 06:56 PM   #1129
needsp is offline needsp  United Kingdom
Hi Nic
I use these-
Rapid Electronics - Cables & Connectors
Seem fine to me, though many who insist on paying huge sums for audiophile connections will doubtless disagree
Paul
Old 14th February 2011, 07:02 PM   #1130
christ is offline christ  Poland
Finally I goy my MUX with power supply.
How to permanentlly connect the AES input that I am going to use in MUX?
Which pins should I connect and with what king of wire at select?
I wanted to eliminate the manual swich with wire.
I also dont need to select other imputs.
Christ
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 10:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 05:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 07:03 PM
