Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 31st January 2011, 12:47 PM   #1111
anonomouse is offline anonomouse  Sweden
Is it a realistic goal to try to combine a buffalo 2 DAC with a myref rev C in the same box? Any issues with interference or incompatibitlity issues, what should I keep in mind?
Old 31st January 2011, 01:03 PM   #1112
Russ White is offline Russ White  United States
Russ White's Avatar
Sure, it should work fine so long as you route wires appropriately and have enough space.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 31st January 2011, 01:18 PM   #1113
Russ,
Thanks for the quick response. If I run signal to the DAC via USB What additional parts "kits" would I need to buy from Twisted pear in order to set this up? (other than the DAC and the USB receiever?). I'm sure this is answered but I seem to get a sea of information when I seach for this info.
Last edited by anonomouse; 31st January 2011 at 01:18 PM. Reason: Too much networking :0P Pear not pair
Old 31st January 2011, 01:22 PM   #1114
Russ White's Avatar
Modules you would need:
- Buf II
- Legato or IVY-III (your choice)
- Placid BP
- Placid
- 9V transformer for Placid
- 12V or 15V(either is fine) transformer for Placid BP
- USB module
Audio
Old 31st January 2011, 01:38 PM   #1115
Thanks!
Old 31st January 2011, 02:45 PM   #1116
Gluca is offline Gluca  Italy
Gluca's Avatar
- Buf II
- Placid BP
- Placid
- USB module
Russ
that raises me some doubts ... so do I need a placid for the BII AND a placid BP for the legato or I can supply the BII and the legato with just on placid BP?
Old 31st January 2011, 02:52 PM   #1117
Russ White's Avatar
You need both because the Buf II needs 5.5V and the Legato +/-12 to 15V
Audio
Old 31st January 2011, 10:09 PM   #1118
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Not that it should really matter but... No, no op amps on-board at all.
The AVCC power supply module is a shunt regulator that uses an opamp.
Naaaaaah, then the BuffaloII should sound lika Creative sound card
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 13th February 2011, 07:23 PM   #1119
pellesmil is offline pellesmil  Norway
pellesmil's Avatar
Some thoughts about internal cabling both digital (S/PDIF) and analog output from the IVY, i am willing to spend some $ in the quest for the perfectly naturally balanced cable, am now running Silk Mk2 interconnects and Furutech rca and xlr .
I have partly decided to run twisted pair of the Silk mk2 at the output both balanced and se,
as for digital input i have ordered a Belden 1694A bnc/bnc and will modify my cd player into bnc.
The question that remains is:
what should i choose as internal wiring from the bnc to the buffalo S/PDIF input, the distance is max 2 in,
should i go for
-1694a shielded? might add some mecanical stress since the 1694 is quite stiff
-1694a stripped and center lead used both for + and -
-Silk mk2?
-other?
-other candidates as for the analogue cabling?
-Thanx
Old 13th February 2011, 09:25 PM   #1120
markusA is online now markusA  Sweden
markusA's Avatar
Pardon a n0ob question...
I have a BII + Placid kit and I'm about to start the build. I'm considering using a 7.5VAC Wall wart. How should I connect the grounds? I assume neither of the two leads from the wall wart are connected to ground?
I'll be using balanced XLR.
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 09:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 04:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 06:03 PM
