#1031 |
Location: Southern Italy - London (UK) - Philadelphia (US)
Hello Buddies,
just because somebody is talking about measurements vs subjective feelings, may I ask whether it has been compared the Buffalo Spdif input with the S/PDIF Transceiver Module? any noticeable difference? Pietro |
#1032 |
Will sound/measure better by I2S rather than direct spdif?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#1033 |
#1034 |
There seems to be a fundamental misunderstanding about the way the ES9018 handles SPDIF.
Where SPDIF has its issues is when SPDIF receivers have to obtain their clock from the SPDIF signal. The ES9018 does not do this at all. The SPDIF data is input completely asynchronously, it is not merely re-clocked, it is never generating a clock in the first place. The truth is both I2S and SPDIF input measure exactly the same. That is because in the end they are treated exactly same. The only difference is what the DAC does to load up the data queue. ![]() Because there is no clock recovery involved, there is really no penalty to using SPDIF except that you are limited to 24bit input where I2S can do 32bit. Just like anything else though, if the signal input is junk, the output will be too. So you still have to have good source.
Less pulp more juice Twisted Pear Audio. |
#1035 |
Speculatively: this will likely depend. Are you questioning if it would be better to use a separate SPDIF receiver and then feed the B-II I2S from that? The SPDIF receiver onboard the ESS 9018 is a pretty sophisticated and unique design (at least from what I can read in the public domain documentation)-I would not be surprised to find that the ESS 9018 SPDIF receiver actually outperforms other options (like the standard Crystal receiver).
Now if the I2S is generated not from SPDIF, but from, say, Russ' forthcoming asynchronous USB receiver, that will be another matter. The async USB to I2S should have an advantage, because the data is never subjected to the clock embedded format of SPDIF, and the necessary clock recovery circuitry (which adds jitter). Additionally, these points may be somewaht moot, due to the ESS' onboard "jitter rejection" via the ASRC, but in reality I doubt it-My B-II certainly sounds different when fed from different sources, so, as usual, less jitter in results in better sound out. Interestingly, one B-II owner has reported on the TPA forums, that the B-II does sound better when fed I2S from a Hiface Evo asynchronous USB interface versus SPDIF from the same source. Could these differences be measured? Sure, but proper measurements of jitter are very complex, and require very specialized gear. Very few people have the gear to really measure jitter differences. Last edited by barrows; 15th December 2010 at 02:53 PM. Reason: added details... |
#1036 | |
Thus, to me sounds like ASRC in a roundabout way. Albeit with a different approach. |
#1037 |
It has the ability to generate a clock yes, but it is *only* that generated clock that is ill and in the case of the ESS DAC it is not used at all. In any way.
![]() SPDIF does not even really "have a clock", but you can derive a clock from it. That is the heart of the issue where standard receivers are used. No clock extraction (which usually requires some type of PLL) is done at all in the case of ESS method. The data is just data which is queued, and gets stuffed into a buffer. Much the same way that asynchronous USB works. SPDIF once you are not running through a PLL to obtain a clock is just like any other 1 wire protocol.
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 15th December 2010 at 04:07 PM. |
#1038 |
I just rigged my Musiland to output I2S last night. So far, both SPDIF and I2S sounds the same.
In my crude setup, so far spdif seems to be a "more solid" signal compared to I2S. With SPDIF I can use lowest dpll bandwidth setting in BuffaloII and with I2S I get drop-outs unless I increase the bandwidth of the DPLL. Russ suspects is noise in the I2S lines. The wires I am using are only 3 inches long.
www.hifiduino.wordpress.com |
#1039 |
Then the noise is likely not from your wiring. More likely from the source.
The DPLL is really finicky about phase noise. You can widen the DPLL window but then you are passing in some of that phase noise down stream.
#1040 | |
For me however the end result is all that matters. And I'm more than satisfied with the result, however it's achieved. The modular nature of the new DAC board allows for an almost infinite freedom to mix and match as one sees fit. And I would certainly recommend going for the Tridents well before going dual mono. It's simply a much more afffordable improvement, and one I'd like to see as an integral part of the BIII board if one ever is going to be designed. |
| Thread Tools | Search this Thread |
| Buffalo Tweaking | jkeny | Digital Line Level | 316 | 10th March 2010 09:14 PM |
| Hello from Buffalo NY | chris emo | Introductions | 1 | 13th July 2007 04:24 AM |
| Buffalo brains | macmeech | Introductions | 1 | 15th June 2004 06:03 PM |
