#1011 | |
Regards FYI I also used |
#1012 | |
#1013 | |
![]() Joking aside, moving from 1 to 3 Placid BPs on the I/V stage is the only upgrade Russ was quite clear about: he couldn't tell the difference. Moving to a dual mono setup is a quite measurable improvement, and going to Trident regulators is a quite noticable improvement. I think those are more worthwhile paths to follow than blindly increasing the PSU count. |
#1014 |
#1015 |
For those of you with an 80MHz Buffalo and looking to go dual-mono, I have a couple 80MHz units on hand. If you want one, send me an email, but please, only if you already have one.
Twisted Pear Audio |
#1016 |
I too would like to see this measurement! While, in theory, dual mono makes sense, in practice I really have reservations when trying to consider if going dual mono really offers an audible advantage...
#1017 |
In my testing there was no measurable difference between dual mono IVY-III and stereo. I have not had a chance to check legato, but I doubt I would see anything different.
The only real reason to go mono would be for the best possible isolation (supply and channel seperation). Really it is simply an arbitrary option. Some people asked for it, and so we delivered. ![]() Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#1018 |
Well - I guess there is at least one measurable difference: twice the output swing!
The same might be attained with a few resistors changes on the I/V stage but that is just to simple (and cheap) for some of us
#1019 |
Actually I have built a dual mono IVY and a dual mono Legato both with -6 db balse stages so no increase in output swing. I don't need that much gain, and prefer the Legato which has less output swing than the IVY. Dual mono sounds much better than I would have suspected in both cases. Maybe its a combination of more perfectly canceling out all of the currents inside and outside the chip as all of the signal is the same with just one channel per DAC along with greater current and noise averaging from summing twice as manny outputs. That said the improvement with the Trident on a dual mono IVY has me preferring it to the dual mono Legato without the Trident upgrade.
I guess what I am saying is the Trident is a must do upgrade with more significant sonic benefit, but dual mono is still very worthwhile just not as cost effective. I will report on the Legato with Trident when it is up. |
#1020 | |
mono mode DNR 135 dB / THD+N -120 dB stereo mode DNR 132 dB / THD+N -118 dB 8-channel mode DNR 129 dB / THD+N -118 dB |
| Thread Tools | Search this Thread |
| Buffalo Tweaking | jkeny | Digital Line Level | 316 | 10th March 2010 09:14 PM |
| Hello from Buffalo NY | chris emo | Introductions | 1 | 13th July 2007 04:24 AM |
| Buffalo brains | macmeech | Introductions | 1 | 15th June 2004 06:03 PM |
