Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 23rd November 2010, 05:46 PM   #1001
LeonvB is offline LeonvB  Netherlands
It depends on the load. For a Placid powering just a plain BII, it'll likely be enough to use a 10VA. The BP + Legato fi. uses more power, and for that it sounds like a bad idea.
Old 27th November 2010, 02:04 PM   #1002
christ is offline christ  Poland
Hi Russ,
I would like to change Buf I (lapizied) with exchanged 9008 chip to 9018 chip
into Dual mono Buf II. BUT I would like to make sure there is not a problem to
have tubes in power section and at the output with BUf II.
Is the Buf II board simmilar to Buf I board in terms of possible lampizition process?
Christ
Old 8th December 2010, 09:53 AM   #1003
JonPike is offline JonPike  United States
Off the wall question...
I and a friend of mine, both have the first Buffalo kits. Mine has been happily running since I finished the build. My friend built his, and it did not work.
He brought it over, I checked voltages, looked for soldering mistakes, etc... nothing. Then, I pulled my firmware/processor chip out and put it in his. TADA!! It Lives... Put his chip in my Buffalo, nothing.
So, looks like he either got a unprogrammed PIC, or it got spiked with ESD while he was handling it, etc. He emailed once or twice, didnt' get a response, (think it was around Brian's move) and hasn't bugged you guys further.
Rather than wait for him to get over his own problem in not bugging you further, I was thinking of using a PIC programming kit and buying the $1-2 part, and copying mine onto a new blank. Only thing I'm worrying about, is there a copy protect on those particular PIC's, and did you use it?
There, now do I know how to take a long time to get around to a question, or what?
Thanks...
Old 8th December 2010, 10:39 AM   #1004
Russ White is offline Russ White  United States
Russ White's Avatar
No we did not use any copy protection on the PIC.
You should be able to copy it. If you like I can even send you the old hex files.
Not that I mind, but this thread is about the Buffalo II, any further conversation about this really should go in the old buffalo thread (just scroll down a bit from our forum index). Actually we can probably handle the rest over email.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 9th December 2010, 12:33 AM   #1005
Great!
Yeah, I got here from a link, didn't know there was an active B-1 thread. I might copy it over there for posterity, it might help someone.
I'll send you my address.
Old 11th December 2010, 04:27 PM   #1006
yiancar is offline yiancar
Hey guys, if i want to add a mux , and a TOSLINK module, do i need an extra power supply except the placid and the placid BP ?
Old 11th December 2010, 05:50 PM   #1007
No, you could put DAC, Mux & Toslink on one Placid
Old 12th December 2010, 08:03 AM   #1008
Tnx
Old 12th December 2010, 07:35 PM   #1009
pellesmil is offline pellesmil  Norway
pellesmil's Avatar
i am waiting for my new-year shipment, consisting of a Buffalo and IVY 3 and some Placids, i prefer a solid powerpack so im gonna run 3 Placids for the IVY (and one for the Dac)
i know the question have been asked before but since im planning to use 4 Placids would it be best to put the Placids in a separate case?
if you recommend putting everything in one box, how far apart must the Placids be from the DAC / IVY and signal lines
If i put the Placids in a separate case, wirering will be longer (probably 1,5ft - 2ft long) but i am planning to use some very good Silkspeak 4mm2 cable to connect the Placids and the IVY / Buffalo.
Ideas appreciated
Old 12th December 2010, 08:39 PM   #1010
Since it vastly increases the length of your powerlines I wouldn't do that. Plus it's really not needed, and that's in multiple ways. It's not required if you use a big enclosure, plus the best sonic improvements are going dual mono and using tridents. If you use Trident regulators you don't need a Placid for the DAC board.
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 09:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 04:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 06:03 PM
