Buffalo II - Page 100 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 22nd November 2010, 05:08 PM   #991
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Default Volumite firmware question
Volumite Firmware for Buffalo-II Stereo/Buffalo-II Dual-Mono/Buffalo32S
I currently have the B32S w/volumite. My assumption is that the programming
(firmware) for the B32S is the same for the B32II. My firmware is from my B32S purchase back in May of 2009.
I ask because I will be switching to the B32II.
Old 22nd November 2010, 05:35 PM   #992
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes the same firmware should work just fine.
Less pulp more juice Twisted Pear Audio.
Old 22nd November 2010, 05:41 PM   #993
LeonvB is offline LeonvB  Netherlands
The older version of the firmware will not work with a dual mono setup.
Old 22nd November 2010, 05:47 PM   #994
Russ White's Avatar
That is correct, if he is going to do dual mono (which he did not say, so I don't know) he would want the newer firmware. Otherwise they are the same. But that would be true for the Buffalo 32 and Well as the Buffalo II
Old 22nd November 2010, 05:53 PM   #995
ichiban's Avatar
Thanks. Mono setup.
Old 22nd November 2010, 05:56 PM   #996
Russ White's Avatar
Originally Posted by ichiban View Post
Thanks. Mono setup.
Then you will want to order new firmware.
Old 22nd November 2010, 06:03 PM   #997
ichiban's Avatar
Oh! What I meant by mono was one B32II (stereo) not dual mono. Sorry.
Thanks again.
Old 22nd November 2010, 10:30 PM   #998
Ared is offline Ared  Hungary
I would like to ask, if the 10VA rated Antek transformers are sufficient to power a placid and a placid bp (9+9 & 15+15) in their default configuration. Here is the data sheet:
http://www.antekinc.com/pdf/AN-01XX.pdf
I considered ordering transformers from TPA, but I have the feeling adding their weight to the buffalo2 box would definetly decrease my chances to get away without additional custom fees
Old 22nd November 2010, 11:04 PM   #999
labjr is offline labjr  United States
What about the Antek 25VA?
Old 22nd November 2010, 11:44 PM   #1000
That's also an option, alltho they might be too big for my case.
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 10:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 05:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 07:03 PM
Copyright 1999-2017 diyAudio
