Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 1st October 2017, 03:27 PM   #311
pixelpusher is online now pixelpusher  United States
Hi Bas,
you just need to make sure that none of the RCA outputs are connected to the turntable ground. You should check it with a continuity meter. If there is no connection then your turntable will not need any modification.
Old 4th October 2017, 12:48 PM   #312
bassiedt is offline bassiedt
Originally Posted by pixelpusher View Post
Hi Bas,
Thanks! This is exactly what I was looking for. And the floating cartridge is than referring to that is cartridge is not grounded at all.
Bas
Old 4th October 2017, 01:52 PM   #313
wcwc is online now wcwc  United States
Originally Posted by bassiedt View Post
I think Greg answered this in his post #184
Thanks for the answer. Do you know if this would work with a +/- 9V regulated supply?
Old 10th February 2018, 11:11 PM   #314
gigigirl is offline gigigirl
Yes, I've been looking at this and also wondered if I could power using 2 x 14 VDC SLA batteries. I like to power all my phono amps from battery power, super quiet that way. Cheers
Retro - A fully symetrical phono stage with RIAA filterHide this!Advertise here!
RIAA Phono Amp Design Sheldon Tubes / Valves 51 24th December 2007 06:45 PM
how build usb phono pre riaa tekton364 Analogue Source 2 28th September 2007 08:50 PM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 04:00 AM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 01:05 PM
ls-37 MM/MC RIAA Phono Amp from diyclub.biz wuffer Tubes / Valves 2 13th November 2004 04:12 PM
