Retro - A fully symetrical phono stage with RIAA filter - Page 31 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 14th November 2016, 11:05 AM   #301
drone is offline drone  Germany
thank you for your advise. Will go with preamp then
Old 19th December 2016, 09:22 AM   #302
alfredd is offline alfredd  Estonia
Originally Posted by Russ White View Post
Hi Folks,
I use XLR with pin 1 connected to the retro GND and pins 2 and 3 connected only to the cartridge outputs. One per channel.
Cheers!
Russ
Whats the point in connecting pin1 to circuitry GND? Would'nt it make sense to connect it to the chassis only?
Old 25th January 2017, 11:48 PM   #303
I recently received Jan Didden's Silent Switcher power supply and plan to try it with the Retro. Wondering how much current the Retro uses I measured it. Both boards measured under 34 mA positive and negative. Playing a record did not seem to change the measurement.
Old 26th January 2017, 12:17 AM   #304
BrianDonegan's Avatar
Final current draw will vary based on the input impedance of the next stage. If you drive headphones (lower impedance), it will be slightly higher.
Old 15th March 2017, 03:13 PM   #305
Both Hi-Z and Lo-Z versions are back in stock.
Old 18th March 2017, 05:22 PM   #306
Oracle1 is offline Oracle1  Greece
Default Retro to unbalanced preamp
Originally Posted by Gosling View Post
Of course you can, but you will lose the benefits of a balanced connection. Just make sure you use properly configured bal-to-unbal cables between the balanced Retro outputs and the unbalanced preamp inputs. Oh, and keep the cable runs as short as possible.
Hello,
Can you explain the cable connection?
Thank you in advance
Old 19th March 2017, 09:31 AM   #307
using just the + output and common ? is that correct? Click the image to open in full size.
RIAA Phono Amp Design Sheldon Tubes / Valves 51 24th December 2007 06:45 PM
how build usb phono pre riaa tekton364 Analogue Source 2 28th September 2007 08:50 PM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 04:00 AM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 01:05 PM
ls-37 MM/MC RIAA Phono Amp from diyclub.biz wuffer Tubes / Valves 2 13th November 2004 04:12 PM
Copyright 1999-2017 diyAudio
