Retro - A fully symetrical phono stage with RIAA filter - Page 22 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 12th February 2014, 12:09 PM   #211
I've got it all going and I am amazed. I'd like to thank Brian for his excellent and complete kits and Russ for his wizardry. The shunt regs were a breeze to set up. Thanks to Russ for thinking the problem through and designing a balanced solution.
Old 12th February 2014, 12:46 PM   #212
Russ White's Avatar
Send a message via Yahoo to Russ White
Excellent!
I hope you are enjoying it.
Brian does do a fantastic job with the kits.
Less pulp more juice Twisted Pear Audio.
Old 12th February 2014, 05:52 PM   #213
With them available, I'm looking at either the kit or boards only for the Low-Z Retro. Are updated schematics & BOM available for the Low-Z version... I'd like to compare the parts needed against my stock to determine whether the kit or the raw boards make more sense for me.
TIA!
Greg in Mississippi
Everything matters!
Old 12th February 2014, 07:20 PM   #214
BrianDonegan's Avatar
I will try to get the BOMs uploaded after work today.
Old 12th February 2014, 07:45 PM   #215
Can all parts be found at mouser? This board seems very interesting!
Old 18th February 2014, 11:25 PM   #216
Yes, for the most part. Consult the Parts List on our site, which lists the vendor and aprt numbers I used. Anything not from Mouser can be substituted with parts that are available there.
Old 19th February 2014, 02:27 AM   #217
Brian,
Thanks for putting the Low-Z BOM & schematic up on the the Retro Page.
RobFreak, I did a quick glance at the BOM & priced the expensive items and unless you have a LOT of the parts sitting around and/or want to go extreme upscale, buying the kit is about as economical as ordering the parts yourself AND the OpAmps come pre-mounted. I don't mind soldering those packages, but there is a time savings and the cost extra (if any) is minimal).
Me, I'm ordering the kit version.
Greg in Mississippi
Everything matters!
Old 19th February 2014, 11:20 AM   #218
4est is offline 4est  United States
Even if you go upscale, it would be a good idea to start out stock to make sure it works. Many "audiophile" parts have issues- size, characteristics and values...
Old 26th February 2014, 03:31 AM   #219
Russ White's Avatar
Yes - I recommend using the stock parts, they sound awesome.
Really the only parts that might need tweaking would be the resistors for gain.
Old 7th April 2014, 10:05 PM   #220
Does this kit work well with a standard phono output from a turntable? That is, would I be able to connect a standard RCA output from the table to the Retro, or is it common for manufacturers to short the RCA connectors together internally?
RIAA Phono Amp Design Sheldon Tubes / Valves 51 24th December 2007 07:45 PM
how build usb phono pre riaa tekton364 Analogue Source 2 28th September 2007 09:50 PM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 05:00 AM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 02:05 PM
ls-37 MM/MC RIAA Phono Amp from diyclub.biz wuffer Tubes / Valves 2 13th November 2004 05:12 PM
Copyright 1999-2017 diyAudio
