Retro - A fully symetrical phono stage with RIAA filter - Page 15 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 12th February 2013, 06:10 PM   #141
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by Nisbeth View Post
Boards now en route
Question: Is there any reason for using 21R resistors on the output and not 22R/22R1?
/U.
No, in fact in many cases those resistors can be replaced with jumpers.
The value is not critical.
Less pulp more juice Twisted Pear Audio.
Old 13th February 2013, 01:55 PM   #142
twluke is offline twluke  Japan
Originally Posted by BrianDonegan View Post
Here is a picture of the kit boards and parts. On board is upside-down to show the op-amps etc.
Quite interesting. I might want to try these boards for DSD archive of my vinyls (128fs) by connecting it to an Ayre ADC (QA-9) and a UDA board . Do I need to order a pair of complete kits for stereo setup or is it okay to order a "single" complete kit for it? Please enlighten me. Thanks in advance.
Tsuneya
Old 10th May 2013, 01:43 PM   #143
pinnocchio's Avatar
Vinyls are great but the cartridge colors the sound. Different cartridge equals different sound signature and not forgetting that listening to the same record many time the sound quality can only go downhill... This is certainly not faithful in the reproduction of the recording. However, I can understand some people prefer a specific sound signature, hence the reason why there's SS and tubes amplifiers/pres and analog and digital medias.
I am not a hater of vinyl at all but I believe that high res files are the way to go when using the proper equipment. However, don't talk to me about MP3 and their siblings.
My friend gave me his Revolver TT and a big boxe of vinyls so I shall give it a try for the fun of it.
Taste are not questionable so it was my personal take on the subject.
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 13th May 2013, 03:15 PM   #144
Default What is the purpose for C1 and C2
Pardon my ignorance
Just curious what is the purpose for C1 and C2 which go across both channels
Old 13th May 2013, 03:19 PM   #145
BrianDonegan's Avatar
They are part of the RIAA filter. Each board is a single balanced channel, so these are not "going across both channels," but are from the + to - nodes of a single channel.
Old 16th May 2013, 10:51 AM   #146
WDYSUN is offline WDYSUN  Italy
WDYSUN's Avatar
Location: Southern Italy - London (UK) - Philadelphia (US)
Hello
To anybody: any experience with this RIAA?
To Russ: I am not totally expert on the subject, I have several LPs and a decent audio card with Balanced Analog inputs, does this circuit easily connect that kind of soundcard?
Best Regards
Pierre
Old 16th May 2013, 12:27 PM   #147
Russ White's Avatar
Sure - it will work fine into any balanced input I can think of.
I use mine into a balanced Joshua Tree attenuator then into a power amp.
Old 18th May 2013, 04:06 PM   #148
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
I've just finished my build and initial impressions are very promising.
Pics etc. here: The “Retro” balanced RIAA stage | theslowdiyer
/U.
DIY projects blog
Old 18th May 2013, 04:09 PM   #149
Russ White's Avatar
Great build! I can't wait to hear your review.
Old 19th May 2013, 09:11 AM   #150
Nisbeth's Avatar
Thanks Russ, will try to get as much listening done as possible over the next week or so.
BTW, what is the right gounding arrangement in the Retro - do you have a drawing handy maybe?
/U.
DIY projects blog
RIAA Phono Amp Design Sheldon Tubes / Valves 51 24th December 2007 06:45 PM
how build usb phono pre riaa tekton364 Analogue Source 2 28th September 2007 08:50 PM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 04:00 AM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 01:05 PM
ls-37 MM/MC RIAA Phono Amp from diyclub.biz wuffer Tubes / Valves 2 13th November 2004 04:12 PM
Copyright 1999-2017 diyAudio
