Retro - A fully symetrical phono stage with RIAA filter - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 21st March 2010, 07:11 PM   #101
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Dead as a Dodo.
GRG
Old 21st March 2010, 07:23 PM   #102
Russ White's Avatar
Send a message via Yahoo to Russ White
Rest assured, the project is not dead. I do apologize for it dragging out, but Brian and I both have had a lot going on both outside and inside TPA.
I will get with him when he is back from his trip about at least offering the boards I have already had made.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 1st April 2010, 04:56 AM   #103
eclectic2k's Avatar
I can understand that! I really don't know how you guys keep up, but thanks for it.
The timing of this is great. I'm finally planning on getting a decent turntable and could use an improved phono pre. As someone without a lot of time myself, your kits are quite nice.
I won't likely need it for a few months - it would be great to know what the rough ETA might be on these? (and maybe an ETA on the second batch in case I miss it...) No detailed schedule or anything, maybe just a WAG?
Thanks,
Chris
Old 23rd April 2010, 04:04 PM   #104
eclectic2k's Avatar
Default stalled
I suppose the retro has stalled... (as is common I see for you and Brian to Juggle so much - it's understood :-)
in looking again at the circuit, I think I'll go with something more conventional anyway. (I don't need balanced out & my TT won't lend itself to run floating) It's a great looking little design, and quite interesting.
What I really need are some placid boards! And those are out too. You guys are keeping quite busy!
Old 23rd April 2010, 04:50 PM   #105
BrianDonegan's Avatar
I am actually away on vacation, so everything is marked "Out Of Stock" until this Saturday (though I don't actually return until Tuesday).
Old 13th May 2010, 05:37 PM   #106
Send a message via MSN to sq225917 Send a message via Skype™ to sq225917
Any forward motion on this guys or is it following the same downwards curve and the Pearl2 phonostage.
it's a damn DIY phonostage conspiracy... i tell ya.
Paradise Pre-reg PSU PCBs
Old 13th May 2010, 05:58 PM   #107
ds23man's Avatar
As I told before: RIP
GRG
Old 13th May 2010, 09:56 PM   #108
I've got faith, they are busy guys...
Old 20th May 2010, 09:45 AM   #109
Default ES9102 for audio measurements
dear Russ:
the ES9102 ADC probably is great for recording music, but it would also
be great for us who makes audio measurements and needs the lowest
possible THD. The ES9102 specs an amazing -120 dB THD!
Russ, as an ADC with the ES9102 is on the agenda, I wonder what kind of digital outputs you plan to include? SPDIF? I2S? USB?
BTW,
have you tried the ES9102 eval board?
The ES9102 is on the agenda. It will be its own module. It will would work just fine with this cct.
Old 20th May 2010, 03:06 PM   #110
Russ White's Avatar
Originally Posted by IngemarR View Post
dear Russ:
BTW,
ESS has not released the ES9102 yet.
I will be using it as soon as it is actually available.
There is no eval board yet to play with.
We have had a module planned for the ES9102 since it was announced. So far all that is available is the product brief.
Cheers!
Russ
RIAA Phono Amp Design Sheldon Tubes / Valves 51 24th December 2007 06:45 PM
how build usb phono pre riaa tekton364 Analogue Source 2 28th September 2007 08:50 PM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 04:00 AM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 01:05 PM
ls-37 MM/MC RIAA Phono Amp from diyclub.biz wuffer Tubes / Valves 2 13th November 2004 04:12 PM
Copyright 1999-2017 diyAudio
