Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 8th April 2012, 03:47 AM   #81
francolargo is offline francolargo  United States
Thanks Russ! I am not ruling out the HD 600s, but if the dog got a hold of them (or anything more expensive!)...
I see the JVCs have 50mm diaphragms and are getting hard to find. Maybe I'll order a pair to hold me for now and then possibly upgrade when the puppy has outgrown the urge to chew (and the Ventus is running).
Frank
Old 8th April 2012, 05:24 AM   #82
Originally Posted by Russ White View Post
one of my favorite pair of over the ear headphones is a cheapish JVC closed can HA-DX1s.
Oh-oh... I saw photos over on head-fi of two different driver units in this same model - one reportedly nice, one reportedly much less engaging. ...went for the sure thing and ordered a pair of HD600s instead. Will NEVER leave them in range of the canine! Thanks again!
Frank
Old 16th April 2013, 03:29 AM   #83
MWL168 is offline MWL168  United States
Hi Russ and Brian:
I have been checking the TWA site for the availability of the Ventus kit. It has been out of stock for quite some time. When do you expect the Ventus kit to be back in stock?
Thanks!
Old 16th April 2013, 01:09 PM   #84
Russ White is offline Russ White  United States
Russ White's Avatar
I think we ran out of boards. Perhaps if there is enough interest I will update it and bring it back.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 16th April 2013, 03:11 PM   #85
Peter Menting is offline Peter Menting  United States
Russ; Have used it for years now as headphone amp driven by Opus DAC and still sounds great. But would love to use it as a preamp as well--(still miss the Kookaburra!)--so if you make Ventus available again, I would be interested.
Pete
Old 16th April 2013, 06:32 PM   #86
If it helps, I can commit to two set of stereo kits. Thanks!
Old 17th April 2013, 12:42 AM   #87
Russ White's Avatar
Would a little SMT scare anyone away?
Audio
Old 17th April 2013, 02:15 AM   #88
If you are referring to working with surface mount parts then it's fine with me.
Old 17th April 2013, 11:52 AM   #89
Having them in the circuit NO! Installing them ---anything over 4 pins with large pads YES!
Pete
Old 17th April 2013, 11:57 AM   #90
Russ White's Avatar
Well the circuit would benefit from matched transistors, and the most cost effective solution for those is SMT - most likely SOT-363 which is 6 pins. But not very hard to solder.
Audio
Introducing VentusHide this!Advertise here!
introducing... lecky Introductions 3 2nd May 2006 09:51 PM
Introducing Myself C.Jackson Introductions 3 19th April 2006 02:47 AM
Introducing ... Jennifer Introductions 1 27th January 2006 09:13 PM
Introducing NEZ mastertech Solid State 9 26th October 2005 01:09 AM
Just introducing myself. 3beanlimit Introductions 0 5th August 2001 04:23 AM
