Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 13th November 2011, 04:22 PM   #71
Ho, I forgot to mention... I would be using the Ventus as a Bal to SE converter to drive a regular Amp, not headphones
Old 13th November 2011, 05:22 PM   #72
BrianDonegan's Avatar
Originally Posted by Lazybutt View Post
Because I want to try to go 100% discrete. (and having no NFB would be a plus)
Not that I have any strong technical justification to do so, and I'm happy with the Legato as is, but there seems to be a widely admitted consensus that Op-amps introduce high order harmonics and/or some kind of "modulation" distortion
Zen I/V Converter
besides, the Legato being a discrete design I feel like it is a pity to introduce ICs in the chain....
...and the Ventus is cheap enough that I want to experiment and listen for myself if there can be even better than the LM4562 !
Thanks !
Ah, but the buffer is not an opamp. It is simply highly-matched and thermally coupled output stage transistors in a single package (see image from the datasheet attached).
The other point of the buffer is to reduce the load on the earlier stage and reduce the output impedance of the circuit.
Twisted Pear Audio
Old 14th November 2011, 10:32 AM   #73
Gosh, I should have taken the time to open the datasheet ! Thanks for replying Brian!
Actually when I saw the distortion figures I was convinced that it was an IC with 1000 transistors and heavy internal feeback loops...
Now, even if the interest of my question decreases with this new info...
just for the beauty of my understanding... if I'm just feeding a pre-amp that happens to use another buffer (namely , a B1 buffer by Nelson Pass) and still want to bypass the LME49600 Buffer (I know I'm getting heavy :P) do I still need as much NFB in the Ventus (or even can I totally get away without NFB ?)
As always thanks for your replies!
Fred
Old 14th November 2011, 11:54 AM   #74
Russ White's Avatar
Send a message via Yahoo to Russ White
The buffer is the output stage, as such it is in the feedback loop and needs to be near the front end. The B1 if not really a good match for the circuit in any case.
Less pulp more juice Twisted Pear Audio.
Old 9th December 2011, 03:11 PM   #75
Default Bal to SE
My situation is similar to Lazybutt but I have opamps to drive.
If I do understand...
1) Since I have a Placid HDBP, I can omit C1,C2, C5, and C6
2) I can omit L1 and R1 (very short wire is used)
3) No use of R3 since no gain is necessary. R5 could be anything?
4) Even if the manual says "from 1K to 10K" , What resistors do you suggest for R2 and R3 if the Legato 3 is used fo IV conversion?
I hope I don't forget anything...
Old 9th December 2011, 03:17 PM   #76
My intention in recommending the Ventus (on the Legato thread) was so you did not need the opamps. They are just another stage that you don't need.
Twisted Pear Audio
Old 7th April 2012, 02:35 PM   #77
Default The puppy chewed my headphones...
Greetings all,
I admit this is frivolous but I write in earnest. When I 're-do' my TPA DACs with a new computer interface, I'm going to add a Ventus. After many years of enjoying TPA products, I trust Brian and Russ implicitly.
So, the puppy recently destroyed my headphones. Looking ahead... To get the best out of my as-yet unordered Ventus (+Buffalo), are there any headphone suggestions? I'm thinking of taking it 'up a notch' from the ~$100, closed-back, 40mm diaphragm sorts I have used previously. [I need flat bass all the way down for track mixing 'in peace'...] Any and all suggestions welcome concerning your 'go-to' favorites! Thanks in advance.
Frank
Old 7th April 2012, 03:12 PM   #78
n_maher is offline n_maher  United States
Frank,
Home Page | InnerFidelity should be able to offer some good advice.
Nate
Old 7th April 2012, 04:08 PM   #79
Thanks Nate,
There is lots of advice and so many different choices out there. On some of the studio engineer forums users report that high-impedance phones sound poorly from some sources. So I'm asking Ventus users/designers what they like. All with the understanding that a preference is not an official endorsement.
F.
Old 8th April 2012, 03:03 AM   #80
Russ White's Avatar
Call me old fashioned, but I still really enjoy My HD600s and HD650s. But I also have several pair of very expensive IEMs (way more than $100). Those typically have about 32ish ohms impedance.
Funny thing, one of my favorite pair of over the ear headphones is a cheapish JVC closed can HA-DX1s. They might be closer to your price range. They sound great. Far better than their price would suggest. Bass is flat - overall one of the best bangs for the buck I have experienced.
introducing... lecky Introductions 3 2nd May 2006 09:51 PM
Introducing Myself C.Jackson Introductions 3 19th April 2006 02:47 AM
Introducing ... Jennifer Introductions 1 27th January 2006 09:13 PM
Introducing NEZ mastertech Solid State 9 26th October 2005 01:09 AM
Just introducing myself. 3beanlimit Introductions 0 5th August 2001 04:23 AM
Page generated in 0.11355 seconds (80.56% PHP - 19.44% MySQL) with 11 queries
