Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 26th December 2009, 09:29 PM   #31
n_maher is offline n_maher  United States
Thanks glt, I'd seen that post and was looking for confirmation that the caps could stay without penalty. I may remove them, since it would allow for much lower profile stacking of the boards.
Also, what's the output impedance of this amp? I'm curious given the inductor and resistor that are in series with the output.
Old 27th December 2009, 01:43 PM   #32
Russ White is offline Russ White  United States
Russ White's Avatar
The output impedance of the Ventus at Audio frequencies is virtually the same as the DCR of the inductor. Which is something less than .05R (I don't have the datasheet open). At frequencies where the inductor impedance begins to rise the parallel resistor will dictate the output impedance. This would be in the Mhz frequency range.
The output inductor is actually optional. I added as a safety measure against capacitive cables. It will keep the amplifier very stable. If you find you don't need it you can simply use a jumper there instead.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 29th December 2009, 01:50 PM   #33
Russ,
Thanks for the output impedance explanation, I'd measured the resistance across the inductor/resistor assembly and found it to essentially be 0 but just wanted to make sure I wasn't missing something.
If you get a chance could you bounce back to page 3 and have a look at a couple of the questions I asked there? Specifically I'm curious about implementing a pseudo gain switch and also how best to approach offering both SE and balanced inputs.
Thanks in advance.
Nate
Old 9th January 2010, 12:21 AM   #34
glt is offline glt  United States
Default A couple of questions before I start building the kit
1- L1 and R1 are both optional? I can connect the output directly to a headphone such as HD580?
2- With balanced input, I can DC couple the output of OPUS?. In fact, no dc blocking caps all the way to the headphone?
3- To nulll the offset: What to do with the inputs when nulling the output
Thanks!
www.hifiduino.wordpress.com
Old 9th January 2010, 10:57 PM   #35
Russ White's Avatar
Thanks!
1) Yes, but you will need to short one of them
2) Yes.
3) The best is to connect them to your source. Or short the inputs to GND.
Cheers!
Russ
Audio
Old 11th January 2010, 02:06 PM   #36
Originally Posted by Russ White View Post
2) For non-inverting use: Reduce R2 to 221R and make R4 47K (this will set the input impedance). Connect -IN to GND. Then adjust R5 and R3 set the gain. Gain = 1+(R5/R3). For unity gain simply omit R3. For example. Using R5 of 1K and R3 of 1K would get you a voltage gain of 2, which is 6db.
Russ,
Could you please clarify how to configure the amp for unity gain? Do you completely omit (do not populate) R3 for unity gain or should you jumper this position? I'm assuming it's the former and not the latter.
Any progress on the manual?
Old 11th January 2010, 08:42 PM   #37
Ferrari is offline Ferrari  Netherlands
Hint: Gain = 1+(R5/R3), as Russ has answered already.
What is the result of the equation if R3 becomes infinite (R3 → ∞) ?
Old 11th January 2010, 08:46 PM   #38
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing Ventus
If you short R3 (0-ohm), the Ventus will throw a DIVIDE_BY_ZERO exception
Old 11th January 2010, 08:48 PM   #39
Thanks Brian, that's what I figured but I'd always rather err on the side of caution and double check before applying power.
Old 26th January 2010, 02:11 AM   #40
Well the Placid BP is up and running checks fine. Any advice, hints, tips, etc. before I think about applying power to the Ventus boards for the first time?
Introducing VentusHide this!Advertise here!
introducing... lecky Introductions 3 2nd May 2006 09:51 PM
Introducing Myself C.Jackson Introductions 3 19th April 2006 02:47 AM
Introducing ... Jennifer Introductions 1 27th January 2006 09:13 PM
Introducing NEZ mastertech Solid State 9 26th October 2005 01:09 AM
Just introducing myself. 3beanlimit Introductions 0 5th August 2001 04:23 AM
