Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 5th September 2009, 01:09 AM   #11
BrianDonegan's Avatar
The Placid (kit) uses FJP5200/FJP1943 devices (80W, 230V, 15A). The only other limiting part are the caps, but they are >=50V. I think you should be fine.
Old 5th September 2009, 01:58 AM   #12
Beefy is offline Beefy  Australia
Originally Posted by tailspn View Post
Actually not. It's all about......
As I said...... and the practical difference is?
Let me explain. I am equal parts technophile, physiologist, and practical to a fault. Part of me wants the absolute best technical solution possible. Part of me wants to know that it actually makes a scientifically testable audible difference. Part of me wants to know whether I can de-OCD to the point where any of it will affect my musical enjoyment at all.
So I guess I'm wondering where we sit in this particular situation. Pure technical pursuit? Extremely minor audible differences? Critical loss of musical enjoyment?
Old 5th September 2009, 02:53 AM   #13
Thanks Brian!
This should work very well for my applications. Looking forward to the kits.
Old 5th September 2009, 03:49 AM   #14
iko is offline iko  Canada
iko's Avatar
On high transient current draws the shunt can supply it on demand, with minimal voltage drop. This, of course, depends how good the regulator is. If a voltage drop is audible or not depends on how large the sag is. Most people tend to hear a very non-subtle difference with a shunt, usually as improved dynamics.
Old 6th September 2009, 03:07 AM   #15
Hi Brian/Russ,
Any idea when this will be available (next 4-6 weeks?)
I was just about to grab a 32S and the 'standard' ps option, but if this is just around the corner, then might hold out for it.
Would love to hear some comparisons between the two
Phil
Buffalo II/Denon AH-D2000
Old 6th September 2009, 06:00 PM   #16
Russ White's Avatar
Send a message via Yahoo to Russ White
It should be able to handle even 1A load as long as the drop is not crazy into into the reg.
The reg only needs about 3V drop for optimal regulation.
500ma should be no trouble at all.
Less pulp more juice Twisted Pear Audio.
Old 7th September 2009, 04:27 PM   #17
Thanks Russ and Brian. This kits should work very well in the applications I have planed for them. Could you please advise what percentage of the load current would you recommend be sunk by the shunt transistor? Aside from the loads inrush current at start-up (charging all the capacitors), the + and - 400MA appears relatively constant under signal conditions. All of the opamps run Class A, and the load on them is above 2K Ohm. I'll measure the delta current before I build the kits and know exactly.
Thanks again,
Tom
Old 7th September 2009, 05:08 PM   #18
Russ White's Avatar
I don't have any solid data yet to back this up, but I would recommend using your maximum AC load(delta current) + 20-50ma + static load.
The shunt part of the circuit utilizes a CFP. The idea is to keep somewhere between 2-10ma going through the CFP driver. This helps it run in its ideal region.
I currently have mine running at 300ma with a static load of about 200ma and a dynamic load of 10-50ma depending on if I am driving headphones. This seems to give me plenty of reserve current.
You can experiment and find the sweet spot for your application.
The supply is pretty forgiving.
Old 7th September 2009, 06:29 PM   #19
Please excuse my being dense. I interpret from your explanation that the entire supply (one polarity) would draw the maximum AC load(delta current) + 20-50ma + static load. The shunt element of the regulator would be adjusted to draw the max AC Load (delta current) plus 20 to 50ma. I'm just trying to get a rough idea of the power dissipation of each of the power transistors on each polarity of the supply. With 4V or so drop across the series pass transistor, the dissipation for .5A is only 2-3W. With 100ma through the shunt transistor, at 24V, that's less than 3W. This is of course only one polarity, but much less heat than I originally thought. Am I missing something?
Also, what does CFP stand for? Constant something I'm sure.
Thanks again,
Tom
Old 7th September 2009, 06:47 PM   #20
eclectic2k's Avatar
How do you think this would work with IVY or Ballsie? If I understand correctly how you've configured it, Placid should be a good upgrade to your LCBPS for most applications...?
I'm planning to order an Opus ASAP, along with an IVY as a balanced buffer and SE converter. A Placid would be a great touch. (even if I need to wait a bit for it)
Thanks!
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Power Supplies 31 16th January 2010 03:05 PM
Bipolar Power supply IC argonrepublic Parts 1 6th December 2008 07:24 PM
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 08:30 AM
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Solid State 0 25th August 2005 04:58 PM
power supply: shunt or series?? AudioGeek Solid State 34 25th July 2004 02:02 AM
Copyright ©1999-2013 diyAudio
