Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 3rd October 2013, 05:41 PM   #181
avr300 is offline avr300  Denmark
avr300's Avatar
Measure between tp_out+ and tp_shunt+
Do the same between tp_out- and tp_shunt-
Post the result.
Old 3rd October 2013, 11:46 PM   #182
nvduybom is offline nvduybom  Viet Nam
nvduybom's Avatar
Thank avr300, with 10VAC input I measured gnd - tp_out += 12.9vdc, gnd - tp_shunt+= 12.9vdc, tp_out- and tp_shunt- is the same . No current load on R2A and R2B.
http://www.vnav.vn/forum
Old 4th October 2013, 06:06 AM   #183
avr300's Avatar
What happen when you turn the current limiting potentiometer(s).
Old 4th October 2013, 07:10 AM   #184
nvduybom's Avatar
I am try to change the current load by VR1A, but VDC of TP_VIN = TP_CCS+ , no current load on R1A .
Old 4th October 2013, 12:47 PM   #185
avr300's Avatar
Lets move this to the support site at
Twisted Pear Audio Support
Go create a case, I'll help you there.
Old 6th October 2013, 07:28 AM   #186
nvduybom's Avatar
Great thank avr300, the problem was solved by my friend, the cause by VR2A, but I don't know why the line negative fail, same .
About the case vol dc down 15 VDC to 1 VDC by I mistake GND with - when connect to Legato.
Now, my board work well .
Old 3rd November 2013, 11:31 PM   #187
picovolt is offline picovolt
Default HD problems, new build, no adjustment at VR2
Built HD and HD PBP at the same time; just tested them. BP is working just as expected, but the HD is not working correctly. All LEDs lit, checked all 550 and 560 transistors (for orientation and solder joints), resistors, solder joints on everything. Twice.
These are most basic measurements, and I can provide photos and more measurements as required.
V in 10.85V AC
DC in 13.45V (TP GND1 & TP VIN)
V out is about 4.05 cold, then lowers to 3.9ish; turning VR2 has no effect at all on V out.
TP V REF is 3.87V which is correct I think.
CSS measures 0.00
Any suggestions where to look?
Edit: cross-posted here:http://www.twistedpearaudio.com/foru...aspx#post20135
Old 26th November 2013, 04:28 PM   #188
orangeart is offline orangeart  United Kingdom
I have an application where I need 35-37 volts out, I have a spare placid, can it be modded to take out put this kind of voltage and if so how much head room would it need?
Stefan
Old 5th December 2013, 06:07 PM   #189
Russ White is offline Russ White  United States
Russ White's Avatar
Not to discourage you, but I would not recommend it unless you understand the circuit well enough to make the changes yourself. If it not the HD version it is not really possible with serious rework.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 11th December 2013, 11:56 PM   #190
pixelpusher is offline pixelpusher  United States
V in 10.85V AC
CSS measures 0.00
Look at your soldering. I recently had the same issue. I checked, double and triple checked my soldering and could not find fault. I reflowed the solder three times and checked it under magnification. I finally sucked all that solder off. It was some boutique "audiophile" solder that a friend gave me. I re-soldered all parts with my good old eutectic solder and no problems now.
Placid-BP Bipolar Shunt Regulated Power SupplyHide this!Advertise here!
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Power Supplies 32 17th June 2017 04:42 PM
Bipolar Power supply IC argonrepublic Parts 1 6th December 2008 07:24 PM
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 08:30 AM
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Solid State 0 25th August 2005 04:58 PM
power supply: shunt or series?? AudioGeek Power Supplies 34 25th July 2004 02:02 AM
