Placid-BP Bipolar Shunt Regulated Power Supply - Page 16 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 15th February 2011, 02:35 PM   #151
Thanks, Brian - I just wanted to play on the safe side.
Is it a good idea to use LCDPS (which I already have) along with Placid in order to spread more even the consumed power? Let's say to power the digital part with LCDPS and the analogue with Placid?
Old 15th February 2011, 06:12 PM   #152
LeonvB is offline LeonvB  Netherlands
That would be a good idea: the digital part is already taken care of with the Tridents. You could use half a LCDPS to power a BII + Trident set, and use a Placid for other modules.
Old 15th February 2011, 07:19 PM   #153
I even thought to use 1/2 LCDPS to power the XO Trident only, the other 1/2 for the other two Tridents and the Placid for the AVcc. Don't know if I will hear any differences, though
Old 15th February 2011, 07:32 PM   #154
Interesting thought, perhaps using 2 LCDPS's would be better though: you could separate the other Tridents too that way.
Old 15th February 2011, 07:35 PM   #155
You know, this is going to be endless, Leon
Old 15th February 2011, 07:35 PM   #156
BrianDonegan's Avatar
You would need to cut traces on the BII board, and for little (if any) benefit.
Old 15th February 2011, 07:53 PM   #157
The only benefit I see for sure is Placid will work in its optimum conditions.
Since I do have LCDPS and Placid boards anyway I might give them a try.
Brian, what current I need to set the Placid for to power AVcc module only, please? The same way it is set for the BII without Tridents or less?
Old 17th September 2011, 08:59 PM   #158
Question Placid HD BP tuning/testing
Could anybody help with Placid HD BP tuning/testing?
I've set VR1A/B to 450R and VR2A/B to 1K as manual says. Turn the power on and what I have:
Input after transformer: 14.9 VAC and 14.6 VAC
TP_VIN+ with TP_CCS+ says 0.593 VDC (593 mA?)
TP_VIN- with TP_CCS- says -0.764 VDC (764 mA?)
TP_GND2 with TP_VREF1+ 3.76 VDC
TP_GND2 with TP_VREF2- -3.78 VDC
TP_GND2 with TP_OUT+ 14.88
TP_GND2 with TP_OUT- -14.05
TP_SHUNT with TP_OUT+ 585 mA
TP_GND2 with TP_OUT- 790 mA
I can change TP_OUT+ with VR2A from +14.9 to 18 V only and TP_OUT- is not changing when I turning VR2B it just stays -14.04!
I thought that VRs are dead after my soldering. But I've turned off PSU, waited and measured resistance of VR1A/B and VR2A/B with turning.
VR1A 8.07K-1.8R
VR1B 9.86K-1.2R
VR2A 0.9R-9.37K
VR2B 0.8R-9.92K
Where should I check? What can be wrong?
Old 17th September 2011, 09:08 PM   #159
Russ White's Avatar
Send a message via Yahoo to Russ White
It could be an issue around the discrete error amplifier. You may want to start a thread on our support forum and post some pictures if you can.
Less pulp more juice Twisted Pear Audio.
Old 17th September 2011, 11:35 PM   #160
reo is offline reo  Canada
Hi
Taken from a previous quote .. LeonvB That would be a good idea: the digital part is already taken care of with the Tridents.
The analogue part is taken care of with .........
regards
rol
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Power Supplies 31 16th January 2010 04:05 PM
Bipolar Power supply IC argonrepublic Parts 1 6th December 2008 08:24 PM
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 09:30 AM
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Solid State 0 25th August 2005 05:58 PM
power supply: shunt or series?? AudioGeek Solid State 34 25th July 2004 03:02 AM
Copyright 1999-2017 diyAudio
