#121 |
Yup. They are also LME49710, and pre-mounted. Time to update the description.
Twisted Pear Audio |
#122 |
And single power placid uses 8pin DIP LME49710 now?
...is I disappear. There is ONLY the music. |
#123 |
No, both single and bp use soic.
#124 |
Ok thanks!
but since I have ordered PCB-s only I don't get them pre-mounted or do I?
#125 | |
#126 |
No problem, I have a steady hand
![]() Just wondering why you switched from opa227 to LME49710?
#127 |
Both will work fine. The LME is lower noise and I had a ton of them on hand.
#128 |
Sorry for stupid question, but can i drive Technics sl1200 from LCBPS (maybe parallel). Technics needs 21 volts inside and around 0.8A max. Or could placid do the job?
#129 |
my 3 Placid BP came with VR1 and 2 at 20ohm , that is iaw the part-list, but not iaw schematics and setup procedure to set it at aprox 50 ohm before powering.
have i missed something here? P |
#130 |
We will need to update the manual. 20R is correct, just adjust it to the max resistance. remember that they have a tolerance, so if it tops out at say 18R or 22R its all fine.
Less pulp more juice Twisted Pear Audio. |
| Thread Tools | Search this Thread |
| Shunt-regulated 24V DC Power Supply for Preamp Modules | snoopyma | Power Supplies | 31 | 16th January 2010 03:05 PM |
| Bipolar Power supply IC | argonrepublic | Parts | 1 | 6th December 2008 07:24 PM |
| Regulated Power Supply. Bipolar, JFET or MOS? | Kenneth Zhu | Tubes / Valves | 4 | 30th December 2007 08:30 AM |
| Shunt-regulated 24V DC Power Supply for Preamp Modules | snoopyma | Solid State | 0 | 25th August 2005 04:58 PM |
| power supply: shunt or series?? | AudioGeek | Solid State | 34 | 25th July 2004 02:02 AM |
