Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 25th April 2010, 05:55 PM   #111
eclectic2k's Avatar
Originally Posted by alboran View Post
I noticed that if you adjust the voltage to +15 V and-15V without load, then when I connect the IVY III, the voltage drops to approximately +9 V .... Is this normal?
sounds like your current is not set high enough for the load. Did you check the current? -- the voltage across R1 & R2 on most recent PlacidBP's
(Older PlacidBP's were R17 & R18...) See the manual....
Old 5th June 2010, 05:18 AM   #112
Hi Brian and Russ,
The manual recommends a 7v transformer for the Placid Power Supply. Is is okay to use a 9v transformer, or would the extra voltage drop create too much heat? (350mA, 5.5v output)
Old 5th June 2010, 11:49 AM   #113
BrianDonegan's Avatar
Originally Posted by chipzahoy View Post
Hi Brian and Russ,
It should be >=7V for 5V use. We sell a 9V transformer for it.
Twisted Pear Audio
Old 5th June 2010, 08:37 PM   #114
Thank you Brian! I'll pair a 9v transformer with the Placid
Old 26th July 2010, 08:48 PM   #115
Boris_The_Blade's Avatar
I received a Placid power supply a little while ago and just finally got around to implementing it. Thought I'd post a few comments and suggestions, sort of a mini-review.
Overall, very good board layout, price is decent. I was using a 2x15V secondary transformer with +/-12VDC outputs. I measured about 400uVrms of noise on an output with a 150mA load and 225 mA through the CCS (shunting 75mA). This was even without the best test setup, using an HP 403B. For comparison, a 7812 makes about 1.6mVrms of noise.
My only suggestions would be to:
1) Add test points for R1 and R2. I was using a meter to measure current across them, when one of the meter lead tips peeked through the soldermask and shorted, ruining one of current-setting potentiometers (VR1/VR2).
2) Ship with 50-ohm variable potentiometers instead of 200-ohm. Most of the turning range is wasted getting the current close to most applications (> 25mA).
Otherwise, very nice product!
Old 9th August 2010, 09:01 PM   #116
glt is offline glt  United States
It got to be lower noise than that?. I am not sure how your measurements relate to specifications, but:
According to specifications, an lt1763 regulator is about 8x lower noise than a 78xx class regulator: H I F I D U I N O: Comparing Noise Figures in Linear Regulators
Your measurements show that the Placid is 4x lower noise than a 7812. Does this mean that a lt1763 regulator is 1/2 the noise than a Placid? It seems that from a design point of view (filtered LED reference, low noise opamp and low noise pass transistors) the Placid should be lower noise than an IC regulator using a bandgap reference
www.hifiduino.wordpress.com
Old 10th August 2010, 04:40 PM   #117
The placid very well could ideally be lower noise, however, that is what I measured, under a non-ideal situation (e.g. inside a chassis with other electronic components). Also keep in mind that the LT1763 series only go up to 5 Volts. Noise would likely go up when using a voltage divider for the reference rather than directly connecting the output to the reference (for 12V output).
Old 10th August 2010, 04:42 PM   #118
Russ White's Avatar
Send a message via Yahoo to Russ White
All things considered its not a bad measurement at all.
Less pulp more juice Twisted Pear Audio.
Old 10th August 2010, 04:43 PM   #119
I agree completely.
Old 15th October 2010, 10:54 PM   #120
Bassivus's Avatar
I'm waiting for the next batch of Buffalo IIs and am reading a bit in the mean time ... I just noticed that Placid BP bom says:
"IC1, IC2 2 Precision Low-noise Bipolar Op Amp Burr-Brown OPA227PA Mouser 595-OPA227PA"
but I can see on the picture that your latest boards use SMD versions, don't they?
Ivica
...is I disappear. There is ONLY the music.
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Power Supplies 31 16th January 2010 03:05 PM
Bipolar Power supply IC argonrepublic Parts 1 6th December 2008 07:24 PM
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 08:30 AM
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Solid State 0 25th August 2005 04:58 PM
power supply: shunt or series?? AudioGeek Solid State 34 25th July 2004 02:02 AM
Copyright ©1999-2013 diyAudio
