Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 26th March 2010, 12:52 AM   #101
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Ooooops sorry I will measure R1 & R2.
Old 26th March 2010, 12:52 AM   #102
Russ White is offline Russ White  United States
Russ White's Avatar
Double check that you have not accidentally used a PNP where a NPN should be, or vice versa.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 26th March 2010, 01:48 AM   #103
Fortunately only do the mistake measuring wrong resistors, now all is ok, I connected the IVY III & adjusted the voltage R13 & R14 to 0,05V
Thank you very for your help.
Now I'm waiting the trimmer 200ohms to setup mine other Placis for the BII (I received 2 trimmers 10K instead one1 10K & one 200 ohms) but don't worry Brian knows because I & send him an e-mail & he answered that will send me the trimmer.
Old 26th March 2010, 01:54 AM   #104
Russ White's Avatar
Very glad to help.
Audio
Old 26th March 2010, 07:37 AM   #105
slam is offline slam  United States
Hi Russ,
I received IVY/III along with Buffalo II and am current building them. One thing I notice is that the following is R13-R16 (180 Ohms 0.1%) are missing from the IVY/III package. What would be the best way to initiate the process of getting the missing parts?
Thanks,
Stanley
Old 28th March 2010, 05:00 AM   #106
Originally Posted by slam View Post
Hi Russ,
Thanks,
Stanley
Brian have taken care of me offline. Thanks you guys for the great work and great support!
Stanley
Old 12th April 2010, 09:00 PM   #107
prooptiki is offline prooptiki  Greece
Which is the better way with one transformer?
Old 12th April 2010, 09:11 PM   #108
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Placid-BP Bipolar Shunt Regulated Power Supply
I would use the first, although you cannot wire it the way you have it.
You could do the second option, but I think it's probably a waste of time, but don't let me stop you.
Old 16th April 2010, 02:39 PM   #109
alboran is offline alboran  Italy
hello
I would ask help, before making trouble ...
tensions (+5.50 ve +15 v - 15v), the two power supply, the buffalo dac II and to the Ivy III, I have to adjust.... with the DAC and IVY III connected or disconnected?
I noticed that if you adjust the voltage to +15 V and-15V without load, then when I connect the IVY III, the voltage drops to approximately +9 V .... Is this normal?
Old 25th April 2010, 06:51 PM   #110
eclectic2k is offline eclectic2k  United States
eclectic2k's Avatar
Hi all, Brian, Russ,
Finally got my Placid BP (v2.1.1) up and running. It sat for quite a while due to other home and family projects...
Had some issues. First I thought I had burned up one of the opamps. Seems that may not have been it.
First thing I noticed was that I couldn't get the voltage above ~ 11V from the + rail. (the - rail was fine all along) I think part of this was a cold solder on QP1 and QP2.
Then I got that worked out, but couldn't get the current across R17 > 100mA. I Pulled my hair out for a bit, then discovered the threads on TP site about the varying Idss on the JFETs that were sent out.
Getting 0.25V across R17 - Placid Dual Power Supply - Twisted Pear Audio Support
jumpering R6 got me to a normal range, so I was happy. I only need about 80mA anyway, so in the end I left R6 as is. Now that I know everything is OK.
After some changes in plans, it's "only" powering a ballsie. Sounds great so far!
Note about cold solder:
I used to be able to solder. Got out of practice. Now that I have a proper temp adjustable station I'm even worse. I also finally got a proper range of tips. The small tip that came with the station was definitely making it hard for me to get some of the larger PCB traces warmed up At least I'm getting some practice again
Placid-BP Bipolar Shunt Regulated Power SupplyHide this!Advertise here!
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Power Supplies 32 17th June 2017 05:42 PM
Bipolar Power supply IC argonrepublic Parts 1 6th December 2008 08:24 PM
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 09:30 AM
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Solid State 0 25th August 2005 05:58 PM
power supply: shunt or series?? AudioGeek Power Supplies 34 25th July 2004 03:02 AM
