Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 13th June 2010, 08:33 PM   #11
chatziva's Avatar
This shows what I am trying to do.
I am trying to build an integrated input selector / preamp / DAC in one box.
The darwin selector connects to a B1 preamp and volume control is achieved by using the header loop in the darwin - is that going to work?
The other potential problem is that the DAC has no volume control with the current wiring shown. The DAC takes input from 3 digital inputs or a USB and outputs directly to a new set of outputs. I could externally link the DAC output with an input in the preamp section but it's probably not a nice solution.
I guess the question is does the DAC need to tap into the B1 preamp and volume control? Or is the windows vista volume control good enough for that job?
The other question is that the DAC output is DC coupled given the current wiring. is that a problem?
Evan
"I don't remember fighting Godzilla, but that's probably what I would've done"
Old 20th July 2010, 01:34 PM   #12
Sorry for hijacking this thread, but does anyone know if/when the Darwin becomes available again?
Old 4th November 2010, 10:52 AM   #13
awpagan is offline awpagan  Australia
I would like to know this too?
Any idea Russ?
Indecision makes the world gone round.
Maybe
Old 4th November 2010, 09:05 PM   #14
BrianDonegan's Avatar
Default Darwin Availability
We have been talking about redesigning the Darwin for quite a while, and other things kept getting in the way (only so many hours in the day, blah blah blah). Also, Darwin has a lot of inputs, probably more than anyone ever really needs (who has 6 sources?).
We were also out of OTTOs, which had functionality which was similar in many ways, but also very different.
We are about to receive some prototypes of a new design that will hopefully fill both needs. Basically, it is a tiny board with a single G6K relay and an optional trigger circuit like that found on the Darwin. This will allow switch triggering of the relay, or digital logic triggering. How does a single relay board help?
Well, they are stackable. You want to replace the OTTO, that's two modules stacked and wired to switch both relays at the same time. You want the functionality of the old Darwin, that's 6 modules stacked with individual triggers (plus any outputs you may want). How about 3 balanced inputs? 6 modules, wired to trigger in pairs.
As I said, these are just prototypes at the moment so we can work out any issues with stacking, triggering, wiring, etc and make needed adjustments. We will post more details as they become available (once the boards get here).
Twisted Pear Audio
Old 4th November 2010, 09:09 PM   #15
Evan
This is exactly the type of think the loop connector is there for.
I think just routing the dac output to one of the Darwin inputs would solve your volume control problem, no?
Twisted Pear Audio
Old 6th November 2010, 11:07 AM   #16
Cobra2 is online now Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Let me see..; 2 Record Decks, (2 x riia), tapedeck, Md, CD/DAC, Tuner, TV, Cabledecoder, DVD, Video/DVD-recorder, Squeezebox/DAC, and whatever that is up for test...
Arne K
Ars longa, vita brevis
Old 6th November 2010, 11:09 AM   #17
Arne K
Still got you covered man (assuming we like how these things work and go together)
Twisted Pear Audio
Old 8th July 2011, 07:12 PM   #18
Send a message via AIM to yldouright Send a message via Yahoo to yldouright
Brian
The 2x6 scheme was and remains an excellent design choice. Please don't fix what ain't broken. We are audiophiles and we need to switch in sources. We may have a favorite but choice is key. What is the status?
Kookaburra, MyRef RevC, and Darwin Selector dimensions stevens Chip Amps 4 31st January 2007 06:12 AM
Boz AP1.7 Input Selector PCB Stones Pass Labs 2 14th November 2006 06:08 AM
input selector lawbadman Digital Source 8 10th September 2005 09:45 AM
Input Selector Semir Solid State 7 28th December 2004 06:18 AM
Input selector: need help Cobra2 Parts 1 8th March 2003 07:31 AM
Page generated in 0.12241 seconds (80.37% PHP - 19.63% MySQL) with 11 queries
