Twisted Pear Audio - Buffalo32S (ES9018 DAC) - Page 95 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 22nd March 2012, 04:30 AM   #941
AAK is offline AAK  United States
Hi F1 FAN,
Here's how to do it. Look for Offset on the output of the AD797.
Al
File Type: pdf Sabre_8_2Channel_64PIN_V3_SCH_Offset.pdf (22.4 KB, 196 views)
Love when you can, Cry when you have to, be who you must, that's part of the plan.
Old 23rd April 2012, 09:12 PM   #942
C37 is offline C37  Belgium
I've just changed the power supply my M2tech Evo with LifeP04 and i'm getting such goosebumps listening to Souad Massi's Live album that i'm wondering if i could also power the 32 digital section with the other pack. It's rated 9,9V -I've measured it at 10,45V fully charged. Is it safe or over the SOR?
Ohm sweet ohm
Old 24th April 2012, 07:30 PM   #943
By ZOLTAR's Avatar
Your voltage 10,45v is ok,but if you go above, it will increase thermal
Old 7th May 2012, 09:17 AM   #944
After 3 years I have finally finished my buffalo32s. Last week the custom frontpanel from Modushop.biz/Hifi2000 in Italy arrived. Beautiful work by Andrea Bettazonni. Now it not only sounds great, but looks great as well (in my opinion at least)!
Scanspeakman
Scanspeak rules!
Old 13th May 2012, 01:27 AM   #945
Bellissimo! Did you use an arduino for the display?
Ohm sweet ohm
Old 13th May 2012, 08:15 AM   #946
kumori is offline kumori  Europe
It certainly looks great.
May I ask how you mounted the display to the front-panel?
I plan to do something similar, but actually i have no clue on how big the rectangular hole must be, to look "professonal". I guess it must be slightly smaller than the display itself...
Also: Should one use a cover glass before the display (for protection)?
I can manage some wood- and also metal-work, but this task does puzzle me.
Old 13th May 2012, 02:31 PM   #947
Thank you. I did not use an arduino for the display. It is a custom solution designed and made by my brother to control the i2c bus. The plan is to add volume control by the remote as well. Now only the source selection can be done by the remote.
Scanspeakman
Scanspeak rules!
Old 13th May 2012, 02:38 PM   #948
The panel itself is 10mm thick. On the rear a 8mm deep cavity is made, which is slightly bigger then the cut out on the front, to hold the display window. I have used 3mm thick grey plexiglass for the window and made a "mask" of black cardboard so then nothing else then the display is visable through the display window. Around the cavity on the back there are 4 m3 threaded holes to bolt the display pcb to the frontpanel. Easyist solution I could think of.
Scanspeakman
Scanspeak rules!
Old 13th May 2012, 05:13 PM   #949
The plexiglass with black frame is a good idea.
Thank you for this tip.
Florian
Old 10th July 2012, 12:18 PM   #950
mesc is offline mesc  Norway
mesc's Avatar
I have volumite with buff32s. When volume knob is turned completely down I still hear music. Is this normal?
I've only recently added the volumite, but strangely I don't seem to remember it being like this when I first installed it. Its now when testing a new amp that I noticed it.
Edit: Another thing thats been bugging me. The spdif button has two positions 1 and ON, so then 1 is off? I am to use i2s input.
Copyright 1999-2017 diyAudio
