Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 6th March 2012, 09:17 PM   #931
C37 is offline C37  Belgium
And anyway,tweak or not, i should "Redde Caesari quae sunt Caesaris", this dac is superb, even if "old". I am really enjoying it.
Thanks TP.
Old 6th March 2012, 10:54 PM   #932
Russ White is offline Russ White  United States
Russ White's Avatar
Thanks TP.
I actually think that DAC is some of my best work, and I am seriously thinking of bringing it back, but slightly revised.
The thing that satisfies me the most is that you are enjoying it.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 7th March 2012, 08:30 AM   #933
TheShaman is offline TheShaman  Europe
I haven't felt a serious need to upgrade from 32S. Upgraditis strikes every now and then (I admit I've added the Buffalo III in the cart a couple of times ) but other projects keep me busy.
Plus I must say it stood it's ground pretty well in head-to-head shootouts with the newer Buffalos.
I like your idea Russ.
You could have a 32S Rev2.0 as an alternative in your lineup.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 19th March 2012, 05:13 AM   #934
hallcon83 is offline hallcon83  United States
Hi Russ or Brian - - I have a Buffalo 32S I am about to build, ( I just bought the wire and solder --- thanks for Russ's help on wire size ) - - - Next Question before I begin ... I have 1-each 32S Dac, 1-each LCDPS, 2-each LCBPS, 2-each 15VA-15v Transformers, 1-each 15VA-9v Transformer - all bought from Twisted Pair Audio, - I am just begining this project and as a newbie would like to make sure all three supplys can be used on the One 32S Board.... is this correct? - Thank You for any help, Sincerely, dean
Old 19th March 2012, 02:23 PM   #935
scanspeakman is offline scanspeakman  Netherlands Antilles
Correct; I am using apprx the same configuration.
Scanspeakman
Scanspeak rules!
Old 19th March 2012, 06:42 PM   #936
Hi Scanspeakman, Thank You for the reply !!!
- What are the other boards that are in your chassis???
I am looking also for some kind of Pre -regulation after the Transformers , before the PSU boards - like CRC or something ... would that help clean up the power a little more? Anyone have some advice? Thank You , Kind Regards, dean
Old 19th March 2012, 06:49 PM   #937
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Twisted Pear Audio - Buffalo32S (ES9018 DAC)
The LCxPS have a CRC filter built in.
Old 19th March 2012, 07:47 PM   #938
Thanks Brian !!! - I guess that I have seen other people that have done more power supply work and say that your Great Buffalo Dac really responds to improved PSUs !..... and I wanted to do something more! But I don't have the bucks right now to buy a better PSU like shunts from you ........ but I could afford a few caps and other parts to mod the psu , So I was looking for any Ideas that others had tried , that had helped ... diy..... it's a disease : ) Kind Regards, dean
Old 22nd March 2012, 12:45 AM   #939
F1 FAN is offline F1 FAN  Canada
I,m considering using the balanced to single ended I-V stage with uf III shown in figure 2 of the following link.http://www.esstech.com/PDF/Applicati...PCB_Layout.pdf
I,m curious as to where the line labeled offset can be derived from?
Old 22nd March 2012, 12:47 AM   #940
Russ White's Avatar
Originally Posted by F1 FAN View Post
I,m considering using the balanced to single ended I-V stage shown in figure 2 of the following link.http://www.esstech.com/PDF/Applicati...PCB_Layout.pdf
You need to create it. Research voltage divider.
Audio
Twisted Pear Audio - Buffalo32S (ES9018 DAC)Hide this!Advertise here!
